[postgis-users] Topology: Simplifying Coastlines with Islands
Michiel J. van Heek michielvanheek at nine-e.org
Mon May 28 05:50:43 PDT 2012
Quoting Sandro Santilli <strk at keybit.net>:
> On Mon, May 28, 2012 at 11:56:13AM +0200, Michiel J. van Heek wrote:
>> Based on your suggestions, I changed the script in three ways (see
>> below for the result):
>> 1. The number of iterations is now a parameter and running down the
>> tolerance uses linear steps for each iteration (0.5, 0.45, 0.4,
>> 0.35, etc.). The division by 2 solution (0.5, 0.25, 0.125, etc.) put
>> a heavy weight on the lower tolerances, whereas it is often
>> worthwile to also try higher tolerances (between initial tolerance
>> and half of the initial tolerance).
>> 2. If an iteration fails because of "not simple" the same iteration
>> is run again, but with "PreserveTopology" now.
>> 3. When all iterations fail, the function returns NULL now, and does
>> not throw an exception. It is now possible to find "unwilling" edges
>> by running:
>> SELECT *
>> FROM (
>>     SELECT
>>         edge_id,
>>         SimplifyEdgeGeom('countries_topology_4', edge_id, 0.5) AS tolerance
>>     FROM countries_topology_4.edge
>> ) AS foo
>> WHERE (tolerance IS NULL);
> Good work ! Maybe make the "curve not simple" handling more tolerant of
> eventual changes in the exception text (only look for "not simple"?).
Good that you mention it. Here is the improved IF line:
                 IF (position('not simple' IN SQLERRM) > 0) AND (xi = '') THEN
But still, this mechanism strongly depends on the formulation of the
exceptions thrown in ST_ChangeEdgeGeom().
> How do your country boundaries look now ? :)
They look pretty good. Most remaining trouble edges are relatively
short. Three long coastlines remain problematic: arctic Canada,
southern/eastern USA, and Brazil. (Red color in attached screenshot.)
Probably because they have some quite large islands very close to the
coastline. If we want to handle these kind of cases automatically, the
easiest way would be to removed the islands, but I don't like that
idea, because some islands may be very big, like the arctic islands of
Canada. It is like removing Great Britain from the map. :-)
Michiel
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120528/9fe37d74/attachment.png>
