[postgis-users] bringing together two polygon datasets
Falko Engel
falko.engel at web.de
Tue May 29 02:58:19 PDT 2012
Am 29.05.2012 11:01, schrieb Sandro Santilli:
> On Tue, May 29, 2012 at 09:48:11AM +0200, Falko Engel wrote:
>> Dear list,
>> I know this is a very basic question, but I can't find any example
>> online for this:
>> I would like to combine two and possibly more (non intersecting)
>> polygon datasets into one. This opperation in called "patch" in the
>> ESRI-world. Could someone give me an example?
> One item for each item in each dataset ?
> CREATE TABLE combined AS SELECT
> 1 as dataset_id, gid, the_geom FROM dataset1
> UNION ALL
> 2 as dataset_id, gid, the_geom FROM dataset2;
> Combine items with the same "id" from each dataset ?
> a.id, st_union(a.the_geom, b.the_geom)
> FROM dataset1 a, dataset2 b
> WHERE a.id = b.id;
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
> postgis-users mailing list
Thanks Sandro,
A colleague just told me to try this:
CREATE TABLE newtab (gid SERIAL NOT NULL PRIMARY KEY, col1 integer, col2
varchar(50));
SELECT AddGeometryColumn ('public','newtab','the_geom',25832,'POLYGON',2);
INSERT INTO newtab (col1, col2) SELECT somecol1, somecol2, the_geom FROM
origdata1;
origdata2;
Worked for me. But I will try your UNION ALL approach as well!
Falko
