[postgis-users] server lacks instrumentation functions
Smaran Harihar
smaran.harihar at gmail.com
Tue May 29 16:47:48 PDT 2012
Thanks for the reply Jeff,
But I already have the latest contrib installed. I restarted the postgres
and the problem still persists.
Also why am I not able to locate Extension in my database, like the
image<http://s1064.photobucket.com/albums/u361/jeffmegwhat/?action=view¤t=postgisextensions.png>you
gave last time?
On Tue, May 29, 2012 at 4:42 PM, Jeff Meyer <jeff at gwhat.org> wrote:
> Hi Smaran -
> I caught that error, too. It's been fixed on the wiki page.
> You shouldn't have to rebuild anything to get this working.
> All you should have to do is:
> # apt-get install postgresql-contrib-9.1
> Then, you may need to start & restart your server or the pgAdmin III
> client to get everything back in order.
> Thanks,
> Jeff
> *From:* Smaran Harihar <smaran.harihar at gmail.com>
> *To:* PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> *Sent:* Tuesday, May 29, 2012 4:33 PM
> *Subject:* [postgis-users] server lacks instrumentation functions
> Hi,
> I installed the PostGIS 2.0 as per the wiki<http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS20Ubuntu1204>.
> Now when I am opening the database in pgadmin3 I am getting the following
> "Guru Hint"
> Server instrumentation
> The server lacks instrumentation functions.
> pgAdmin III uses some support functions that are not available by default
> in all PostgreSQL versions. These enable some tasks that make life easier
> when dealing with log files and configuration files.
> The adminpack is installed and activated by default if you are running the
> 'official' pgInstaller distribution of PostgreSQL for Windows and is
> included as a contrib module with all versions of PostgreSQL 8.2 and above.
> However, if you are running any other version of PostgreSQL you will need
> to manually install it. To do so, simply copy the appropriate adminpack
> source code to the /contrib directory of your pre-configured PostgreSQL
> source tree. You can download the adminpacks here.
> Run the following commands (substituting admin for admin81 if required):
> # cd $PGSRC/contrib/admin
> # make all
> # make install
> So I downloaded the admin pack 81 and placed it in the contrib/admin as
> instructed and I am trying to "make all"
> But I am getting the following error,
> Makefile:13: ../../src/Makefile.global: No such file or directory
> Makefile:14: /contrib/contrib-global.mk: No such file or directory
> make: *** No rule to make target `/contrib/contrib-global.mk'. Stop.
> Do I require the Server Instrumentation installed? Also last time I was
> able to navigate from the database to the "Extension". Now my database does
> not have Extension
> Thanks & Regards
> Smaran Harihar
> postgis-users mailing list
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120529/f488a1a1/attachment.html>
