[postgis-users] Speeding up point-in-polygon search using ST_SimplifyPreserveTopology?
Paul Ramsey
pramsey at opengeo.org
Wed May 30 06:57:41 PDT 2012
On Wed, May 30, 2012 at 9:47 AM, Evan Martin
<postgresql at realityexists.net> wrote:
> Thanks, Paul, but do you have any suggestions on how I can cut up the
> polygons properly? As I posted, ST_Intersection doesn't work properly on the
> ones spanning the dateline and I don't know how else to do it. Maybe there's
> some obvious trick I'm missing. (I haven't looked at the code, but it seems
> a bit strange to me that ST_Intersects works, but not ST_Intersection - so
> PostGIS can somehow figure out that they intersect, but can't figure out
> where?)
Intersects() is run on the spheroid, Intersection is a hack wrapper on
a reprojection into planar and then back again. Did we talk about this
already? Changing the hack to use gnomic instead of UTM might improve
things.
> By the development work do you mean ticket 1796 or something else? Either
> way, any estimate on when it might get done? :)
Yes, that's the ticket. It might get done for 2.1, or it might not.
Money makes the world go 'round. All things being equal it will get
done, since it's something that personally interests me, but things
might not be equal if I'm paid for some other work instead.
P.
> Regards,
> Evan
> On 30/05/2012 11:35 PM, Paul Ramsey wrote:
>> Evan,
>> Beyond the cutting-up-of-large-things as Stephen suggests, there is
>> the extra development work to optimize the edge searching routines
>> with an internal index on the objects (and caching that index once
>> built). Something for 2.1 :)
>> P.
>> On Mon, May 28, 2012 at 10:08 AM, Evan Martin
>>> Hi all,
>>> I have a table of ~350 multi-polygons and ~185,000 points and I need to
>>> find
>>> which points are inside which multi-polygons. Some polygons are quite
>>> large
>>> and span the dateline, so I'm using geography ST_DWithin for this (with a
>>> tolerance of 100m). My initial query looks like this (simplified):
>>> SELECT ...
>>> FROM points, polygons
>>> WHERE ST_DWithin(point, real_area, 100)
>>> This works, but it takes about 90 minutes. I'm trying to make it faster
>>> by
>>> using ST_SimplifyPreserveTopology. That worked very nicely for my
>>> "adjacent
>>> polygons" problem
>>> [http://postgis.refractions.net/pipermail/postgis-users/2012-January/031992.html],
>>> because all polygons were modified in the same way, but this is trickier.
>>> Since I'm modifying the polygon, but not the point, the results are
>>> different. So I thought maybe I could do this in two phases: if the point
>>> is
>>> well within or well outside the polygon then take the result of the
>>> "simplified" check as correct, but if it's close to the border then check
>>> it
>>> properly, ie.
>>> SELECT ...
>>> WHERE ST_DWithin(point, simple_area, 20000)
>>> AND (ST_Distance(point, simple_border)> 20000 OR ST_DWithin(point,
>>> real_area, 100))
>>> simple_area = ST_SimplifyPreserveTopology(real_area::geometry,
>>> 0.01)::geography and simple_border = the exterior ring of simple_area.
>>> This takes about 18 minutes (a 5x improvement) and gives very similar
>>> results, but not quite the same. It falls down on polygons that have
>>> rhumblines along parallels, because they get turned into great circle
>>> lines.
>>> Eg. the original polyon may have a rhumbline approximated as (24 10,25
>>> 10,26
>>> 10,27 10), ST_SimplifyPreserveTopology does its job and simplifies it to
>>> (24
>>> 10,27 10) and then ST_DWithin on geography treats it as a great circle
>>> line,
>>> giving an incorrect result. I tried inserting extra points to
>>> "unsimplify"
>>> the rhumblines, but that itself is very slow and also quite a hack,
>>> because
>>> I can't really be sure which lines were supposed be rhumblines when
>>> looking
>>> at the simplified polygon. I feel like I'm so close and this is a very
>>> silly
>>> little problem - but it is a problem.
>>> Could anyone suggest a way to work around this? Or a different approach
>>> to
>>> the whole thing?
>>> Thanks,
>>> Evan
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
