[postgis-users] spaces between tiles
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Thu May 31 08:57:09 PDT 2012
Joan,
The ST_HillShade function does not support tiled coverage...
Depending on how big is your coverage (how many pixels by how many pixels) you could import it non tiled and then use ST_Tile to tile in the DB.
ST_Tile is not part of PostGIS 2.0. You will find it here:
http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_tile.sql
Pierre
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Joan
> Sent: Thursday, May 31, 2012 11:53 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] spaces between tiles
> Hi guys,
> I have just run the st_hillshade function. A row of pixels around the resulting
> raster are missing, causing spaces between tiles.
> What could be the problem?
> Regards
> Joan
