[postgis-users] Querying PostGIS Raster with MultiPoint
Tobias Bieniek Tobias.Bieniek at gmx.de
Thu Nov 15 14:55:25 PST 2012
Hi Guys
I've posted the following question on StackExchange already, but it
seems that nobody was able to help me.
(http://gis.stackexchange.com/questions/40371/querying-postgis-raster-with-multipoint)
For one of my projects using PostGIS 2 I have a table with GPS tracks
(igc_files). It holds records including a MULTIPOINT() column that has
about 1,000 points for each record and a column that has an array of
the corresponding timestamps. I also have a raster table (elevations)
that should at some point hold all of the SRTM elevation data. For now
I have only imported a few relevant areas though.
What I want to do is get the elevation for each point of one certain
record and the corresponding timestamps. I have implemented an naive
approach and it does work, but I'm wondering about its performance
implications. This is how it currently looks:
SELECT timestamps[location_id] AS timestamp,
       ST_VALUE(elevations.rast, subq.location) AS elevation
FROM elevations, (
    SELECT (ST_DUMP(igc_files.locations)).path[1] AS location_id,
           (ST_DUMP(igc_files.locations)).geom AS location
    FROM igc_files
    WHERE igc_files.id = 1
) AS subq, igc_files
WHERE igc_files.id = 1 AND
      ST_INTERSECTS(subq.location, elevations.rast) AND
      ST_VALUE(elevations.rast, subq.location) IS NOT NULL
Since this is a GPS track and the points are not that far apart,
PostGIS could assume that the next point is in the same raster tile
and check that tile first before checking the index again from the
top. Is that actually done by PostGIS or is it just starting to search
the index from the top for each of the points?
I have tried to use ST_INTERSECTION() instead of ST_VALUE() and
feeding in the MULTIPOINTdirectly, but that was actually even slower
by a few orders of magnitude. Is there a feature/function of PostGIS
that I am missing to do this more efficiently?
