[postgis-users] Trouble building 2.1 SVN
Rhys A.D. Stewart rhys.stewart at gmail.com
Sun Nov 18 13:51:23 PST 2012
Greetings,
it is indeed there. Here is the output:
________________
-L/usr/lib64 -lgeos_c -lexpat -lxerces-c -lpthread -lNCSEcw -lNCSEcwC
-lNCSCnet -lNCSUtil -ljasper -L/usr/lib -lnetcdf -lhdf5 -lgif -ljpeg
-Lexternal/lib -lgeotiff -Lexternal/lib -ltiff -lpng
-L/usr/lib64/postgresql-9.2/lib64 -lpq -lz -L/usr/ -L/usr//lib -lm -lrt
-ldl -lspatialite
Still not sure how to rectify this problem though.
Thanks,
Rhys
On Sun, Nov 18, 2012 at 3:11 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> It looks like something is up with your GDAL build/setup.  Check your
> output from:
> gdal-config --dep-libs
> I'm expecting the "external/lib" to be found in the output.
> -bborie
> On Sun, Nov 18, 2012 at 8:39 AM, Rhys A.D. Stewart
> <rhys.stewart at gmail.com> wrote:
> > Greetings all,
> > Trying to build postgis 2.1 svn but running into some issues. The
> > compilation bugs out with:
> > _____________________________
> > ../../libtool: line 4992: cd: external/lib: No such file or directory
> > libtool: link: cannot determine absolute directory name of `external/lib'
> > make[2]: *** [raster2pgsql] Error 1
> > make[2]: Leaving directory
> `/var/tmp/portage/dev-db/postgis-2.1.0/work/postgis-2.1.0SVN/raster/loader'
> > make[1]: *** [rtloader] Error 2
> > make[1]: Leaving directory
> > `/var/tmp/portage/dev-db/postgis-2.1.0/work/postgis-2.1.0SVN/raster'
> > make: *** [all] Error 1
> > Not sure what to make of it. I've attached the entire build log and
> > environment file. Am running gentoo linux. Building it fails using potage
> > (gentoo's package system) with a custom ebuild and fails if i try to
> build
> > it  'by hand'.
> > Thanks,
> > Rhys
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121118/518d5f12/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121118/518d5f12/attachment.obj>
