[postgis-users] connecting to postgis from remote machines
Mark Volz
MarkVolz at co.lyon.mn.us
Mon Nov 19 07:36:54 PST 2012
Hello,
I am able to connect to postgis on a local machine, however I am having trouble connecting to PostGIS from remote machines. The specific error I get is "FATAL: no_pg.conf entry for host "10.0.xxx.xxx", user "Editor", database "postgis20", SSL off." I modified postgresql.conf so that the listen_addresses is set to *, and made sure that ssl is set to off. In addition I added a line in pg_hba.conf for type host, database all, user all, IP-address *.
Questions:
1) I was not clear what to use for the method in pg_hba.conf. I set it to md5 as that is what the other methods are using.
2) For testing I am using qgis 1.8.0 on a 32 bit machine to connect to postgis on a 64 bit machine. Are there any known issues with connecting to 64 bit host from a 32 bit machine?
Thank You
Mark Volz
GIS Specialist
