[postgis-users] connecting to postgis from remote machines
Stephen V. Mather
svm at clevelandmetroparks.com
Tue Nov 20 11:46:48 PST 2012
Hi Mark,
I really wouldn't recommend that, unless you are behind a firewall
you really really really trust... . Even then, I wouldn't recommend those
settings. At least restrict your subnet, and preferably which users as well
(you can use an online subnet calculator, e.g.
http://www.subnet-calculator.com/ to help with this). With the settings you
have you will (eventually) have someone doing things on your database that
you never intended, and likely maliciously. You can (and should) ping the
PostgreSQL mailing list with recommended settings for listen addresses and
basic (but sane) security practices.
Best,
Steve
Stephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Tuesday, November 20, 2012 1:03 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] connecting to postgis from remote machines
Hello,
I was able to allow remote connections by changing the listen address to *
in postgresql, and adding the following line in pg_hba.conf
host all all all md5
Mark Volz
GIS Specialist
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
