[postgis-users] ST_MapAlgebraExpr() : what is mean [rast] ?
Mahavir Trivedi
mahavir.trivedi at gmail.com
Tue Nov 20 23:16:20 PST 2012
dear
sir first to thanking you for suggestion about query
alter table dem demtest add column map_rast raster
update demtest set map_rast= ST_mapalgebraExpr(rast,'16BUI'::text,'CASE
WHEN [rast] BETWEEN 10 AND 200 THEN [rast] ELSE NULL')
IT is Execute success fully .
BUT when I export it using JAVA program It's size of Tiff is 9 KB . mean i
mage not visible
SELECT ST_COUNT(map_rast,false) from demtest
4641304
SELECT ST_COUNT(map_rast) from demtest
0
with regards
Mahavir trivedi
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121121/17095444/attachment.html>
