[postgis-users] ST_MapalgebraExpr() function
Mahavir Trivedi
mahavir.trivedi at gmail.com
Fri Nov 23 02:24:54 PST 2012
dear
i stored tiff image in postgis raster.
how do i get image which have only pixel range between 10 to 40 ?
raster2psql -s 4326 -I -C -M -d d:\test.tiff -F public. demtest > test.sql
alter demtest add column map_rast raster
update demtest set map_rast=ST_MapAlgebraExpr(rast,'16BUI':: text,'case
when [rast] between 20 and 40 then [rast] else NULL end')
when i using java programm for export ing : select ST_AsPNG(rast) from
demtest then output image is perfect.
but when i write query select ST_AsPNG(map_rast) from demtest. then output
image is not as i required.
with regards and thanks
mahavir trivedi
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121123/617dd382/attachment-0001.html>
