[postgis-users] Removing shapefile from Postgres
Smaran Harihar smaran.harihar at gmail.com
Sat Nov 24 15:51:15 PST 2012
Thanks for the response Sandro. When I execute,
echo "SELECT DropGeometryTable('pimapine')" | psql -U smaranh geospecies
this is the output that I am getting back,
ERROR:  function dropgeometrytable(unknown) does not exist
LINE 1: SELECT DropGeometryTable('pimapine')
HINT:  No function matches the given name and argument types. You might
need to add explicit type casts.
Thanks,
Smaran
On Thu, Nov 22, 2012 at 7:24 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Nov 21, 2012 at 05:43:34PM -0700, Smaran Harihar wrote:
> > Hi,
> > I added a shapefile to the PostGIS using,
> >     ogr2ogr -f PostgreSQL PG:"host=server_ip user=username dbname=dbname
> > password=password" yourshapefile.shp;
> > Now I want to remove it. What is the command line code for that?
> Assuming the table created by ogr2ogr is named "yourshapefile"
> (which you should verify) the call would be:
> echo "SELECT DropGeometryTable('yourshapefile')" | psql -U username dbname
> --strk;
>  http://www.cartodb.com - Map, analyze and build applications with your
> data
>                                        ~~ http://strk.keybit.net
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121124/8c293051/attachment-0001.html>
