[postgis-users] Contours of rasters without or with tiles
Mathieu Basille basille at ase-research.org
Fri Nov 23 12:53:17 PST 2012
Dear PostGIS users,
Here is a simple case: I'd like to extract the contour polygon of a given
raster. The dedicated function should be ST_Polygon. If I run it on the
raster imported without tiles, I get one polygon per island/continent,
which is exactly what I want. However, if the raster uses tiles, I get one
polygon per island/continent for each tile (which makes sense). I could
merge them using ST_Union, but I was unable to do that completely: some
polygons do get merged, but not all. This can be fairly problematic in my
case, since I'm using buffers of the resulting polygon, which means I need
one polygon per island/continent.
Example case, with the simple raster attached:
Importation without tiles:
raster2pgsql -s 4326 -I -C -M raster.tif test.raster | psql -h localhost -d
database -U pguser
Importation with tiles:
raster2pgsql -s 4326 -t 5x5 -I -C -M raster.tif test.raster_tile | psql -h
localhost -d database -U pguser
Using ST_Polygon:
CREATE TABLE test.pol AS
SELECT ST_Polygon(rast) FROM test.raster;
CREATE TABLE test.pol_t AS
SELECT ST_Polygon(rast) FROM test.raster_tile;
Using ST_Union on the result:
CREATE TABLE test.pol_tu AS
SELECT ST_Union(ST_Polygon(rast)) FROM test.raster_tile;
See the picture attached to see the result. 'pol' and 'pol_t' give the
expected results, but not 'pol_tu'. Is this an expected behaviour? Is there
a workaround to this problem?
Thanks in advance for any hint!
Mathieu.
# SELECT PostGIS_Full_Version();
     postgis_full_version
  POSTGIS="2.1.0SVN r10597" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 2.0dev, released 2011/12/29" LIBXML="2.8.0"
LIBJSON="UNKNOWN" TOPOLOGY RASTER
~$ whoami
Mathieu Basille, PhD
~$ locate --details
University of Florida \\
Fort Lauderdale Research and Education Center
(+1) 954-577-6314
http://ase-research.org/basille
~$ fortune
« Le tout est de tout dire, et je manque de mots
Et je manque de temps, et je manque d'audace. »
  -- Paul Éluard
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121123/f4bc9406/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121123/f4bc9406/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121123/f4bc9406/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121123/f4bc9406/attachment-0003.png>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121123/f4bc9406/attachment.tif>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121123/f4bc9406/attachment.xml>
