[postgis-users] Adding raster to PostGIS database
José Pedro Santos
zpsantos1 at hotmail.com
Tue Nov 27 00:13:49 PST 2012
Try to see if you have Postgis correct installed. In the PGSQL console type: SELECT * FROM Postgis_lib_version();
If not is correct install try to do this in the terminal as postgresql SU:
1 - Find /usr -name 'rtpostgis.sql' (copy the path of this file)
2 - pgsql -d yourDBname -f thepreviouspath
3 - Try again to import the file
Best Regards
José Santos
Date: Mon, 26 Nov 2012 21:40:25 -0700
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Adding raster to PostGIS database
Oh it seems the error was due to ownership being in the name of another user.
Now I am able to get the gdalinfo,
Driver: GTiff/GeoTIFFFiles: Quercus_acutifolia_raw.tif
Size is 3864, 1583Coordinate System is:GEOGCS["WGS 84", DATUM["unknown", SPHEROID["WGS84",6378137,298.257223563]], PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]Origin = (-179.960724061474451,86.577964063072983)Pixel Size = (0.093000000000000,-0.090400000000000)Metadata: AREA_OR_POINT=Area
Image Structure Metadata: COMPRESSION=LZW INTERLEAVE=BANDCorner Coordinates:Upper Left (-179.9607241, 86.5779641) (179d57'38.61"W, 86d34'40.67"N)
Lower Left (-179.9607241, -56.5252359) (179d57'38.61"W, 56d31'30.85"S)Upper Right ( 179.3912759, 86.5779641) (179d23'28.59"E, 86d34'40.67"N)Lower Right ( 179.3912759, -56.5252359) (179d23'28.59"E, 56d31'30.85"S)
Center ( -0.2847241, 15.0263641) ( 0d17' 5.01"W, 15d 1'34.91"N)Band 1 Block=3864x1 Type=Float32, ColorInterp=Gray Min=0.000 Max=0.923 Minimum=0.000, Maximum=0.923, Mean=0.000, StdDev=0.000
NoData Value=-3.39999999999999996e+38 Metadata: STATISTICS_MAXIMUM=0.92262234256096 STATISTICS_MEAN=0 STATISTICS_MINIMUM=5.6834812171638e-19 STATISTICS_STDDEV=0
But when I execute,
raster2pgsql -c -s 4326 -I Quercus_acutifolia_raw.tif public.Quercus_acutifolia_raw | psql -h localhost -d dbname -U usr
I am still not able to create a Table? This is the output,
Processing 1/1: Quercus_acutifolia_raw.tifPassword for user postgres: BEGINNOTICE: CREATE TABLE will create implicit sequence "quercus_acutifolia_raw_rid_seq" for serial column "quercus_acutifolia_raw.rid"
ERROR: type "raster" does not existLINE 1: ...us_acutifolia_raw" ("rid" serial PRIMARY KEY,"rast" raster); ^
ERROR: current transaction is aborted, commands ignored until end of transaction blockERROR: current transaction is aborted, commands ignored until end of transaction blockERROR: current transaction is aborted, commands ignored until end of transaction block
ROLLBACK
Thanks,Smaran
On Mon, Nov 26, 2012 at 3:07 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
Run the following...
gdalinfo Quercus_acutifolia_raw.tif
If that returns an error, something may be wrong with the tif file.
-bborie
On 11/26/2012 02:03 PM, Smaran Harihar wrote:
> But I am executing the command in the directory where it is located
> I can list that raster using `ls`
> On Mon, Nov 26, 2012 at 2:46 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
>> That error would only happen if raster2pgsql can't find the file in your
>> current working directory. raster2pgsql supports relative paths for
>> input rasters.
>> -bborie
>> On 11/26/2012 01:37 PM, Smaran Harihar wrote:
>>> Thanks for the reply bborie,
>>> I ran this command,
>>> public.Quercus_acutifolia_raw | psql -h localhost -d rasterdb -U postgres
>>> But this is the new error,
>>> ERROR: Unable to read raster file: Quercus_acutifolia_raw.tif
>>> Thanks,
>>> Smaran
>>> On Mon, Nov 26, 2012 at 2:27 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
>>>> -D is not a valid flag recognized by raster2pgsql. Remove the flag as
>>>> raster2pgsql is assuming that -D is a file.
>>>> -bborie
>>>> On 11/26/2012 01:23 PM, Smaran Harihar wrote:
>>>>> Hi Guys,
>>>>> I am trying to add a raster to PostGIS database using,
>>>>> raster2pgsql -c -D -s 4326 -I Quercus_acutifolia_raw.tif
>>>>> public.Quercus_acutifolia_raw | psql -h localhost -d dbnm -U usr
>>>>> But I am getting this error,
>>>>> ERROR: Unable to read raster file: -D
>>>>> Any idea what is wrong? The database already has numerous point and
>>>> polygon
>>>>> shapefiles. Is that a problem that I cannot add rasters to the same
>>>>> database having shapefiles?
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>> Bborie Park
>>>> Programmer
>>>> Center for Vectorborne Diseases
>>>> UC Davis
>>>> 530-752-8380
>> Bborie Park
>> Programmer
>> UC Davis
>> 530-752-8380
Bborie Park
Programmer
UC Davis
530-752-8380
Thanks & RegardsSmaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121127/f4d390e0/attachment.html>
