[postgis-users] Effectively combining rasters
Kim Bisgaard
kib at dmi.dk
Wed Nov 28 00:01:39 PST 2012
Thanks Bborie,
That is an alternative solution, but it gives about the same runtime here, perhaps because I use PostgreSQL 9.1 and not 9.2.
"Sort (cost=22.14..22.15 rows=1 width=64) (actual time=1402.745..1402.746 rows=14 loops=1)"
" Sort Key: (st_x(st_centroid((foo.AAA).geom))), (st_y(st_centroid((foo.AAA).geom)))"
" Sort Method: quicksort Memory: 26kB"
" CTE pos"
" -> Result (cost=0.00..0.01 rows=1 width=0) (actual time=0.001..0.001 rows=1 loops=1)"
" CTE foo"
" -> Nested Loop (cost=0.01..22.09 rows=1 width=96) (actual time=101.003..1402.181 rows=210 loops=1)"
" Join Filter: _st_intersects(B.rast, pos.geom, NULL::integer)"
" -> Nested Loop (cost=0.00..10.81 rows=1 width=64) (actual time=0.198..0.203 rows=1 loops=1)"
" Join Filter: _st_intersects(A.rast, pos.geom, NULL::integer)"
" -> CTE Scan on pos (cost=0.00..0.02 rows=1 width=32) (actual time=0.005..0.006 rows=1 loops=1)"
" -> Index Scan using A_rast_gist on A (cost=0.00..8.27 rows=1 width=32) (actual time=0.022..0.024 rows=1 loops=1)"
" Index Cond: ((rast)::geometry && pos.geom)"
" -> Index Scan using B_rast_gist on B (cost=0.00..8.27 rows=1 width=32) (actual time=0.014..0.021 rows=1 loops=1)"
" -> CTE Scan on foo (cost=0.00..0.03 rows=1 width=64) (actual time=101.041..1402.723 rows=14 loops=1)"
" Filter: ((AA).geom = (BB).geom)"
"Total runtime: 1402.833 ms"
I will see if I can find a way to try it on a 9.2 ...
If there is no better idea as to reformulate the query? I will have to merge results in the program - with 60ms per raster it's faster to do
in the program and not in the DB.
Thanks again,
Kim
On 2012-11-27 19:04, Bborie Park wrote:
> WITH pos AS (
> SELECT ST_GeomFromText('MULTIPOLYGON(((15.000 54.800,15.000
> 55.000,14.800 55.000,14.800 54.800,15.000 54.800)))',4326) AS geom
> ), foo AS (
> SELECT
> st_intersection(A.rast,1,pos.geom) AS AA,
> st_intersection(B.rast,1,pos.geom) AS BB
> FROM pos
> JOIN A
> ON st_intersects(A.rast,pos.geom)
> JOIN B
> ON st_intersects(B.rast,pos.geom)
> SELECT
> st_x(st_centroid((AA).geom)) AS lon,
> st_y(st_centroid((AA).geom)) AS lat,
> (AA).val AS "AAA",
> (BB).val As "BBB"
> FROM foo
> WHERE (AA).geom = (BB).geom
> ORDER BY lon, lat;
Kim Bisgaard
Application Development Division Phone: +45 3915 7562 (direct)
Danish Meteorological Institute Fax: +45 3915 7460 (division)
