[postgis-users] Possible bug with PostgreSQL 9.2 / PostGIS... unable to set default privileges
Bborie Park bkpark at ucdavis.edu
Wed Nov 28 07:30:21 PST 2012
Sounds like something you should be asking on the pgadmin-support
mailing list as they're the only ones that can fix the problem.
http://www.pgadmin.org/support/list.php
-bborie
On Wed, Nov 28, 2012 at 7:27 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I am using PGAdmin III to work with my Postgres 9.2 / PostGIS 2 database.  I am able to modify privileges for databases, schemas, and tables for any role.  I noticed however that in the Default Privileges tab, only the public role appears in the Role / Group dropdown.  So it appears that I cannot modify the default privileges.  Has anyone else noticed this behavior?   I did not have any problems with PostGRES 9.1 / PostGIS 2.
> Thanks
> Mark Volz
> GIS Specialist
> p.s.  I should mention I am using the windows 64 bit version of the software.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
