[postgis-users] ST_Intersection error side location conflict
Paolo Crosato
paolo.crosato at targaubiest.com
Fri Nov 30 02:03:55 PST 2012
Il 29/11/2012 18:10, Sandro Santilli ha scritto:
> On Thu, Nov 29, 2012 at 05:56:42PM +0100, Paolo Crosato wrote:
>> Hi,
>> I tried all the suggestions.
>> 1) All geometries are closed, select count(*) from adminbndy4 where
>> ST_IsClosed(geom)='f' gives 0
>> 2) Yes I will add the intersect clause to the composite query on the
>> table, however for now I'm just trying to figure out why the example
>> I posted gives an error.
>> 3) 4) All the geometries in the table are valid, select count(*)
>> from adminbndy4 where ST_IsValid(geom)='f' returns 0. Anyway I tried
>> the buffer trick on the example I posted, but the error is still
>> there.
>> Any other suggestion?
>> I thought about rounding to the 4th decimal with ST_SnapToGrid to
>> simplify things a bit, but It would be the very last option.
> Tried upgrading GEOS to 3.3.6 ?
I upgraded to 3.3.6, but the problem was still there. It turned out to
be a very simple issue, I was building the mask rectangle clockwise
rather than counterclockwise.
Once I reordered the points, eveything worked well, and blazing fast too :)
Paolo
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
