[postgis-users] Tiger geocoder, Spanish street types are pushed to the end
Paragon Corporation lr at pcorp.us
Tue Oct 2 03:38:52 PDT 2012
Attaching to the ticket would be great :)
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of James
Marca
Sent: Tuesday, October 02, 2012 1:23 AM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] Tiger geocoder,Spanish street types are pushed
to the end
Leo and Regina,
Thanks for the tips.  To follow up, I ended up going in a slightly different
direction, as I really wanted the whole segment from one intersection to
another, not just the intersection point.
My method relies more on regexes than yours, but I also have the advantage
that I'm only trying to geocode one data source, not any random address.
Unfortunately, my source data is even less consistent than the census in how
it treats abbreviations!  I'm getting about 70% match rate, and will have to
do the rest by process of elimination I think.
One thing that might help your effort is I did a quick translation of the
abbreviations pdf into a csv document.  I can post it to github or attach it
to the bug report if you are interested. I use it by testing for both the
full name and any possible abbreviations in the regex compare.
Regards,
James
On Thu, Sep 27, 2012 at 04:20:41PM -0400, Paragon Corporation wrote:
> James,
> Which version are you using?  I assume the 2.1.0SVN one?
> That we can probably change the structure of a bit since it hasn't
> been released yet and can probalby get away with change the norm_addy
> type as well which we've been dragging our feet on a bit Mostly
> because it brings along a bunch of upgrade issues we'd need to provide
> for people using tiger already.
> If  you look at the file
> tiger_2011\tables\lookup_tables_2011.sql
> The street_type_lookup values is what controls how Camino is treated.
> That probably will require another field at some point we are guessing
> to better follow the Tiger Feature name types convention of Prefix
> Type / Suffix type (and possibly Spanish column) they document in
> http://www.census.gov/geo/www/tiger/tgrshp2011/TGRSHP2011_TechDoc_E.pd
> f
> I think we are missing a bunch too.  Haven't bothered reconciling
> their list with what we have.
> That's probably a good start.  The normalize_address function itself
> is kinda scary to looku at but you can if you want.  We were hoping to
> modularize it a bit more later.
> Hope that helps,
> Leo and Regina
> http://www.postgis.us
> James Marca
> Sent: Thursday, September 27, 2012 4:06 PM
> pushed to the end
> On Thu, Sep 27, 2012 at 03:56:53PM -0400, Paragon Corporation wrote:
> > James,
> > Sadly this is a known issue and one we haven't settled on the best
> > way to fix without resorting to major surgery.
> oops, my bad.  I forgot to look at the open tickets.
> > Here is the ticket for it:
> > http://trac.osgeo.org/postgis/ticket/1118
> > If you can add your examples to the ticket and add yourself to cc
> > for the ticket that would be great.  We'll add these to our regress
> > tests when we finally come up with a palpable fix.
> I'll do it now
> > In MA we have similar issues, but mostly with french streets locally
> > they are a rare occurrence, but Leo feels your pain about Cali since
> > he's a San Diego boy.
> I was going to say this might be a problem in other countries, but,
> duh, Tiger is US-only.
> > Sorry we couldn't be more helpful.
> I'm a reasonably competent hacker, so if you point me at the right
> file(s) I'd be happy to try my hand.
> Regards,
> James
> postgis-users mailing list
