[postgis-users] Installing 64-bit PostGIS 2.0.1 with WindowsInstaller
Paragon Corporation lr at pcorp.us
Tue Oct 9 18:04:00 PDT 2012
Could be a password issue, though that usually gets written to the log
files.
Does your password have any ' or " in it.  I think we might still have issue
with that.
It sounds like it might have got passed copying over the files, so you can
probably just enable PostGIS anyway in the database of your choosing and see
if that works.
Just connect to the database you want to spatially enable and try:
CREATE EXTENSION postgis;
 If it does, you are probably fine.  We eventaully plan to get rid of the
template_postgis database as it's been nothing but frustration for us.  e.g.
the postgis_topology doesn't change the database path when used from a
template and if we didn't have it, we wouldn't even need to have to ask for
postgres credentials, thus dismissing a long standing issue we've been
dragging our feet to fix and a part that's taking up a good chunk of our
setup script :)
Thanks,
Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Nathan
Swain
Sent: Tuesday, October 09, 2012 3:57 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Installing 64-bit PostGIS 2.0.1 with
WindowsInstaller
I'm trying to install the 64-bit PostGIS 2.0.1 using the windows installer
(http://postgis.refractions.net/download/windows/#postgis-installers).The
operating system I am installing it on is Windows Server 2008 R2 Enterprise
64-bit. I have already installed the following version of PostgreSQL:
PostgreSQL 9.2.1, compiled by Visual C++ build 1600, 64-bit. When I install
PostGIS, it throws the following error: Database creation failed. It asks if
I would like to view the error log. When I reply with "Yes," it does not
write the file and the installation does not complete. So I don't know what
the exact error is. I have also tried installing it using the stack builder
with the same result. Any help would be welcome.
Here is the details report from the installer:
Output folder: C:\Users\NATHAN~1\AppData\Local\Temp\postgis_installer
Installer running on 64-bit host
UserName=postgres
Password=*********
Port=****
Checking for existing PostGIS installation...
Output folder: C:\Program Files\PostgreSQL\9.2\bin
Extract: libcharset-1.dll... 100%
Extract: libgcc_s_sjlj-1.dll... 100%
Extract: libgdal-1.dll... 100%
Extract: libgeos-3-3-5.dll... 100%
Extract: libgeos_c-1.dll... 100%
Extract: libiconv-2.dll... 100%
Extract: libproj-0.dll... 100%
Extract: libstdc++-6.dll... 100%
Extract: pgsql2shp.exe... 100%
Extract: raster2pgsql.exe... 100%
Extract: shp2pgsql.exe... 100%
Skipped: libxml2-2.dll
Output folder: C:\Program Files\PostgreSQL\9.2\bin\postgisgui
Extract: freetype-config... 100%
Extract: gettext.sh... 100%
Extract: glib-gettextize... 100%
Extract: glib-mkenums... 100%
Extract: gtk-builder-convert... 100%
Extract: gtk-update-icon-cache.exe.manifest... 100%
Extract: libasprintf-0.dll... 100%
Extract: libatk-1.0-0.dll... 100%
Extract: libcairo-2.dll... 100%
Extract: libcairo-gobject-2.dll... 100%
Extract: libcairo-script-interpreter-2.dll... 100%
Extract: libeay32.dll... 100%
Extract: libexpat-1.dll... 100%
Extract: libfontconfig-1.dll... 100%
Extract: libfreetype-6.dll... 100%
Extract: libgailutil-18.dll... 100%
Extract: libgdk-win32-2.0-0.dll... 100%
Extract: libgdk_pixbuf-2.0-0.dll... 100%
Extract: libgio-2.0-0.dll... 100%
Extract: libglib-2.0-0.dll... 100%
Extract: libgmodule-2.0-0.dll... 100%
Extract: libgobject-2.0-0.dll... 100%
Extract: libgthread-2.0-0.dll... 100%
Extract: libgtk-win32-2.0-0.dll... 100%
Extract: libintl-8.dll... 100%
Extract: libpango-1.0-0.dll... 100%
Extract: libpangocairo-1.0-0.dll... 100%
Extract: libpangoft2-1.0-0.dll... 100%
Extract: libpangowin32-1.0-0.dll... 100%
Extract: libpng14-14.dll... 100%
Extract: libpq.dll... 100%
Extract: shp2pgsql-gui.exe... 100%
Extract: ssleay32.dll... 100%
Extract: zlib1.dll... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\bin\postgisgui\etc\fonts
Extract: fonts.conf... 100%
Extract: fonts.dtd... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\bin\postgisgui\etc\gtk-2.0
Extract: gtkrc... 100%
Extract: im-multipress.conf... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\bin\postgisgui\etc\pango
Extract: pango.modules... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\bin\postgisgui\lib
Extract: atk-1.0.def... 100%
Extract: atk-1.0.lib... 100%
Extract: cairo.def... 100%
Extract: cairo.lib... 100%
Extract: expat.lib... 100%
Extract: fontconfig.def... 100%
Extract: fontconfig.lib... 100%
Extract: freetype.def... 100%
Extract: freetype.lib... 100%
Extract: gailutil.lib... 100%
Extract: gdk-win32-2.0.lib... 100%
Extract: gdk_pixbuf-2.0.lib... 100%
Extract: gio-2.0.def... 100%
Extract: gio-2.0.lib... 100%
Extract: glib-2.0.def... 100%
Extract: glib-2.0.lib... 100%
Extract: gmodule-2.0.def... 100%
Extract: gmodule-2.0.lib... 100%
Extract: GNU.Gettext.dll... 100%
Extract: gobject-2.0.def... 100%
Extract: gobject-2.0.lib... 100%
Extract: gthread-2.0.def
Extract: gthread-2.0.lib... 100%
Extract: gtk-win32-2.0.lib... 100%
Extract: intl.lib... 100%
Extract: libasprintf.dll.a... 100%
Extract: libatk-1.0.dll.a... 100%
Extract: libcairo-gobject.dll.a... 100%
Extract: libcairo-script-interpreter.dll.a... 100%
Extract: libcairo.dll.a... 100%
Extract: libexpat.def... 100%
Extract: libexpat.dll.a... 100%
Extract: libfontconfig.dll.a... 100%
Extract: libfreetype.dll.a... 100%
Extract: libgailutil.dll.a... 100%
Extract: libgdk-win32-2.0.dll.a... 100%
Extract: libgdk_pixbuf-2.0.dll.a... 100%
Extract: libgio-2.0.dll.a... 100%
Extract: libglib-2.0.dll.a... 100%
Extract: libgmodule-2.0.dll.a... 100%
Extract: libgobject-2.0.dll.a... 100%
Extract: libgthread-2.0.dll.a... 100%
Extract: libgtk-win32-2.0.dll.a... 100%
Extract: libintl.def... 100%
Extract: libintl.dll.a... 100%
Extract: libpango-1.0.dll.a... 100%
Extract: libpangocairo-1.0.dll.a... 100%
Extract: libpangoft2-1.0.dll.a... 100%
Extract: libpangowin32-1.0.dll.a... 100%
Extract: libpixman-1.a... 100%
Extract: libpng.def... 100%
Extract: libpng.lib... 100%
Extract: libpng14.dll.a... 100%
Extract: libz.dll.a... 100%
Extract: pango-1.0.def... 100%
Extract: pango-1.0.lib... 100%
Extract: pangocairo-1.0.def... 100%
Extract: pangocairo-1.0.lib... 100%
Extract: pangoft2-1.0.def... 100%
Extract: pangoft2-1.0.lib... 100%
Extract: pangowin32-1.0.def... 100%
Extract: pangowin32-1.0.lib... 100%
Extract: zdll.lib... 100%
Extract: zlib.def... 100%
Files\PostgreSQL\9.2\bin\postgisgui\lib\gdk-pixbuf-2.0\2.10.0
Extract: loaders.cache... 100%
Files\PostgreSQL\9.2\bin\postgisgui\lib\glib-2.0\include
Extract: glibconfig.h... 100%
Files\PostgreSQL\9.2\bin\postgisgui\lib\gtk-2.0\2.10.0\engines
Extract: libpixmap.dll... 100%
Extract: libwimp.dll... 100%
Files\PostgreSQL\9.2\bin\postgisgui\lib\gtk-2.0\include
Extract: gdkconfig.h... 100%
Files\PostgreSQL\9.2\bin\postgisgui\lib\gtk-2.0\modules
Extract: libgail.dll... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\bin\postgisgui\lib\pkgconfig
Extract: atk.pc... 100%
Extract: cairo-fc.pc... 100%
Extract: cairo-ft.pc... 100%
Extract: cairo-gobject.pc... 100%
Extract: cairo-pdf.pc... 100%
Extract: cairo-png.pc... 100%
Extract: cairo-ps.pc... 100%
Extract: cairo-svg.pc... 100%
Extract: cairo-win32-font.pc... 100%
Extract: cairo-win32.pc... 100%
Extract: cairo.pc... 100%
Extract: fontconfig.pc... 100%
Extract: freetype2.pc... 100%
Extract: gail.pc... 100%
Extract: gdk-2.0.pc... 100%
Extract: gdk-pixbuf-2.0.pc... 100%
Extract: gdk-win32-2.0.pc... 100%
Extract: gio-2.0.pc... 100%
Extract: gio-windows-2.0.pc... 100%
Extract: glib-2.0.pc... 100%
Extract: gmodule-2.0.pc... 100%
Extract: gmodule-no-export-2.0.pc... 100%
Extract: gobject-2.0.pc... 100%
Extract: gthread-2.0.pc... 100%
Extract: gtk+-2.0.pc... 100%
Extract: gtk+-win32-2.0.pc... 100%
Extract: libpng.pc... 100%
Extract: libpng14.pc... 100%
Extract: pango.pc... 100%
Extract: pangocairo.pc... 100%
Extract: pangoft2.pc... 100%
Extract: pangowin32.pc... 100%
Extract: pixman-1.pc... 100%
Files\PostgreSQL\9.2\bin\postgisgui\share\themes\Default\gtk-2.0-key
Files\PostgreSQL\9.2\bin\postgisgui\share\themes\Default\gtk-2.0-key-old
Extract: gtkrc
Files\PostgreSQL\9.2\bin\postgisgui\share\themes\Emacs\gtk-2.0-key
Files\PostgreSQL\9.2\bin\postgisgui\share\themes\MS-Windows\gtk-2.0
Files\PostgreSQL\9.2\bin\postgisgui\share\themes\Raleigh\gtk-2.0
Output folder: C:\Program Files\PostgreSQL\9.2\doc\contrib
Extract: postgis-2.0.pdf... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\gdal-data
Extract: compdcs.csv... 100%
Extract: coordinate_axis.csv... 100%
Extract: cubewerx_extra.wkt... 100%
Extract: datum_shift.csv... 100%
Extract: ecw_cs.wkt... 100%
Extract: ellipsoid.csv... 100%
Extract: epsg.wkt... 100%
Extract: esri_extra.wkt... 100%
Extract: esri_StatePlane_extra.wkt... 100%
Extract: esri_Wisconsin_extra.wkt... 100%
Extract: gcs.csv... 100%
Extract: gcs.override.csv... 100%
Extract: gdalicon.png
Extract: GDALLogoBW.svg... 100%
Extract: GDALLogoColor.svg... 100%
Extract: GDALLogoGS.svg... 100%
Extract: gdal_datum.csv... 100%
Extract: geoccs.csv... 100%
Extract: gt_datum.csv... 100%
Extract: gt_ellips.csv... 100%
Extract: header.dxf... 100%
Extract: nitf_spec.xml... 100%
Extract: nitf_spec.xsd... 100%
Extract: pci_datum.txt... 100%
Extract: pci_ellips.txt... 100%
Extract: pcs.csv... 100%
Extract: pcs.override.csv... 100%
Extract: prime_meridian.csv... 100%
Extract: projop_wparm.csv... 100%
Extract: s57agencies.csv... 100%
Extract: s57attributes.csv... 100%
Extract: s57attributes_aml.csv... 100%
Extract: s57attributes_iw.csv... 100%
Extract: s57expectedinput.csv... 100%
Extract: s57objectclasses.csv... 100%
Extract: s57objectclasses_aml.csv... 100%
Extract: s57objectclasses_iw.csv... 100%
Extract: seed_2d.dgn... 100%
Extract: seed_3d.dgn... 100%
Extract: stateplane.csv... 100%
Extract: trailer.dxf... 100%
Extract: unit_of_measure.csv... 100%
Extract: vertcs.csv... 100%
Extract: vertcs.override.csv... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\lib
Extract: postgis-2.0.dll... 100%
Extract: rtpostgis-2.0.dll... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\pgAdmin III\plugins.d
Extract: postgis.shp2pgsql-gui.ini... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\share\contrib\postgis-2.0
Extract: legacy.sql... 100%
Extract: legacy_minimal.sql... 100%
Extract: postgis.sql... 100%
Extract: postgis_comments.sql... 100%
Extract: postgis_drop_after.sql... 100%
Extract: postgis_upgrade_20_minor.sql... 100%
Extract: raster_comments.sql... 100%
Extract: rtpostgis.sql... 100%
Extract: rtpostgis_legacy.sql... 100%
Extract: rtpostgis_upgrade_20_minor.sql... 100%
Extract: spatial_ref_sys.sql... 100%
Extract: tiger_geocoder_comments.sql... 100%
Extract: topology.sql... 100%
Extract: topology_comments.sql... 100%
Extract: topology_upgrade_20_minor.sql... 100%
Extract: uninstall_legacy.sql... 100%
Extract: uninstall_postgis.sql... 100%
Extract: uninstall_rtpostgis.sql... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\history_table
Extract: history_table.sql... 100%
Extract: README... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\ogc_test_suite
Extract: 1_schema.sql... 100%
Extract: 2_queries.sql... 100%
Extract: 3_cleanup.sql... 100%
Extract: Makefile... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\rpm
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\rpm\patches
Extract: filter-requires-perl-Pg.sh
Extract: postgis-configure.patch... 100%
Extract: postgis-javamakefile.patch... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\rpm\spec
Extract: postgis.spec... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\template_gis
Extract: createdb.postgis.1... 100%
Extract: createdb.postgis.in... 100%
Extract: mktemplate_gis.1... 100%
Extract: mktemplate_gis.in... 100%
Extract: mktemplate_gis.sh.in... 100%
Extract: postgis_env.sh.in... 100%
Extract: postgres_lib.sh.in... 100%
Extract: profile... 100%
Extract: rmtemplate_gis.1... 100%
Extract: rmtemplate_gis.in... 100%
Extract: rmtemplate_gis.sh.in... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\tiger_geocoder
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\tiger_geocoder\tiger_2
011
Extract: census_loader.sql... 100%
Extract: create_geocode.bat... 100%
Extract: create_geocode.sh... 100%
Extract: create_geocode.sql... 100%
Extract: geocode_settings.sql... 100%
Extract: tiger_loader_2011.sql... 100%
Extract: upgrade_geocode.sql... 100%
Extract: upgrade_geocoder.bat... 100%
Extract: upgrade_geocoder.sh... 100%
011\geocode
Extract: census_tracts_functions.sql... 100%
Extract: geocode.sql... 100%
Extract: geocode_address.sql... 100%
Extract: geocode_intersection.sql... 100%
Extract: geocode_location.sql... 100%
Extract: includes_address.sql... 100%
Extract: interpolate_from_address.sql... 100%
Extract: other_helper_functions.sql... 100%
Extract: rate_attributes.sql... 100%
Extract: reverse_geocode.sql... 100%
011\legacy_import\tiger2008
Extract: import_tiger_shps.sh... 100%
011\normalize
Extract: count_words.sql... 100%
Extract: end_soundex.sql... 100%
Extract: get_last_words.sql... 100%
Extract: location_extract.sql... 100%
Extract: location_extract_countysub_exact.sql... 100%
Extract: location_extract_countysub_fuzzy.sql... 100%
Extract: location_extract_place_exact.sql... 100%
Extract: location_extract_place_fuzzy.sql... 100%
Extract: normalize_address.sql... 100%
Extract: pprint_addy.sql... 100%
Extract: state_extract.sql... 100%
011\regress
Extract: geocode_regress... 100%
Extract: geocode_regress.sql... 100%
Extract: normalize_address_regress... 100%
Extract: normalize_address_regress.sql... 100%
Extract: regress.sql... 100%
Extract: reverse_geocode_regress... 100%
Extract: reverse_geocode_regress.sql... 100%
011\tables
Extract: lookup_tables_2011.sql... 100%
011\topology
Extract: tiger_topology_loader.sql... 100%
011\utility
Extract: cull_null.sql... 100%
Extract: levenshtein_ignore_case.sql... 100%
Extract: nullable_levenshtein.sql... 100%
Extract: set_search_path.sql... 100%
Extract: utmzone.sql... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\WFS_locks
Extract: test.sql... 100%
Extract: WFS_locks.c... 100%
Extract: WFS_locks.sql.in... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\extras\wkb_reader
Extract: printwkb.c... 100%
Extract: readwkb.c... 100%
Extract: wkbtest.h... 100%
Files\PostgreSQL\9.2\share\contrib\postgis-2.0\proj
Extract: alaska... 100%
Extract: conus... 100%
Extract: epsg... 100%
Extract: esri... 100%
Extract: esri.extra... 100%
Extract: FL... 100%
Extract: GL27... 100%
Extract: hawaii... 100%
Extract: IGNF... 100%
Extract: MD... 100%
Extract: nad.lst... 100%
Extract: nad27... 100%
Extract: nad83... 100%
Extract: ntf_r93.gsb... 100%
Extract: ntv1_can.dat... 100%
Extract: null... 100%
Extract: nzgd2kgrid0005.gsb... 100%
Extract: other.extra... 100%
Extract: proj_def.dat... 100%
Extract: prvi... 100%
Extract: stgeorge... 100%
Extract: stlrnc... 100%
Extract: stpaul... 100%
Extract: TN... 100%
Extract: WI... 100%
Extract: WO... 100%
Extract: world... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\share\extension
Extract: postgis--2.0.0--2.0.1.sql... 100%
Extract: postgis--2.0.0alpha1--2.0.1.sql... 100%
Extract: postgis--2.0.0alpha2--2.0.1.sql... 100%
Extract: postgis--2.0.0alpha3--2.0.1.sql... 100%
Extract: postgis--2.0.0alpha4--2.0.1.sql... 100%
Extract: postgis--2.0.0alpha5--2.0.1.sql... 100%
Extract: postgis--2.0.0alpha6--2.0.1.sql... 100%
Extract: postgis--2.0.0beta1--2.0.1.sql... 100%
Extract: postgis--2.0.0beta2--2.0.1.sql... 100%
Extract: postgis--2.0.0beta3--2.0.1.sql... 100%
Extract: postgis--2.0.0beta4--2.0.1.sql... 100%
Extract: postgis--2.0.0rc1--2.0.1.sql... 100%
Extract: postgis--2.0.0rc2--2.0.1.sql... 100%
Extract: postgis--2.0.1.sql... 100%
Extract: postgis--unpackaged--2.0.1.sql... 100%
Extract: postgis.control... 100%
Extract: postgis_topology--2.0.0--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0alpha1--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0alpha2--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0alpha3--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0alpha4--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0alpha5--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0alpha6--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0beta1--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0beta2--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0beta3--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0beta4--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0rc1--2.0.1.sql... 100%
Extract: postgis_topology--2.0.0rc2--2.0.1.sql... 100%
Extract: postgis_topology--2.0.1.sql... 100%
Extract: postgis_topology--unpackaged--2.0.1.sql... 100%
Extract: postgis_topology.control... 100%
Extract: postgis_topology.sql... 100%
Output folder: C:\Program Files\PostgreSQL\9.2\utils
Extract: create_undef.pl... 100%
Extract: postgis_proc_upgrade.pl... 100%
Extract: postgis_restore.pl... 100%
Extract: profile_intersects.pl... 100%
Extract: read_scripts_version.pl... 100%
Extract: svn_repo_revision.pl... 100%
Extract: test_estimation.pl... 100%
Extract: test_geography_estimation.pl... 100%
Extract: test_geography_joinestimation.pl... 100%
Extract: test_joinestimation.pl... 100%
Creating template database...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121009/fb55cc7d/attachment.html>
