[postgis-users] Select polygons within polygon with PostGIS 2.0
Sandro Santilli strk at keybit.net
Thu Oct 11 01:40:17 PDT 2012
On Thu, Oct 11, 2012 at 09:49:03AM +0200, Michal Zimmermann wrote:
> Got it! There was no username associated with the search_path and it
> seems that was causing the trouble.
I don't understand it, can you please tell us more about how you fixed it ?
The search_path `` "$user", public, topology `` seems sane to me.
--strk;
> On 10/11/12, Michal Zimmermann <zimmicz at gmail.com> wrote:
> > Variable search_path for postgistemplate DB has the following values:
> > "$user", public, topology.
> >> How do I find out?
> >> On 10/11/12, Sandro Santilli <strk at keybit.net> wrote:
> >>>> > On Thu, Oct 11, 2012 at 09:02:58AM +0200, Michal Zimmermann wrote:
> >>>> >> Hi,
> >>>> >> I tried with SELECT CreateTopology('kraje_topo', 4326); and got the
> >>>> >> following error: ERROR: AddGeometryColumn() - invalid SRID. Is there
> >>>> >> something special I need to do before creating topology?
> >>>> > The SRID must be in spatial_ref_sys.
> >>>> > Did you forget to load spatial_ref_sys.sql ?
> >>>> No, if I try select * from spatial_ref_sys where srid=4326, I get
> >>>> exactly one result. The topology table belongs to topology scheme,
> >>>> while the spatial_ref_sys belongs to public scheme, could that be a
> >>>> problem?
> >>> Uhm, good question. Is "public" not in your search path ?
> >>> --strk;
> >>>  http://www.cartodb.com - Map, analyze and build applications with your
> >>> data
> >>>                                        ~~ http://strk.keybit.net
> >>> _______________________________________________
> >>> postgis-users mailing list
> >>> postgis-users at postgis.refractions.net
> >>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> Michal Zimmermann (zimmi)
> >> WWW: http://www.zimmi.cz
 http://www.cartodb.com - Map, analyze and build applications with your data
