[postgis-users] "service" field in postgres
Sandro Santilli
strk at keybit.net
Thu Oct 11 10:50:42 PDT 2012
On Thu, Oct 11, 2012 at 11:10:30PM +0530, chathura silva wrote:
> I try it by making it blank, but does not work :(
I suggest you carefully read the qgis user manual and if you
still have troubles ask on the qgis-users mailing list.
It will help, if you ask, to include more information about
_how_ it doesn't work (if you get any error message, for instance)
--strk;
> On Thu, Oct 11, 2012 at 10:47 PM, Sandro Santilli <strk at keybit.net> wrote:
> > On Thu, Oct 11, 2012 at 06:05:10PM +0530, chathura silva wrote:
> > > hi all,
> > > when I try to connect postgresQL via Quantumgis (QGIS) , it asks for a
> > > service field to connect to the server. What is the value of the field
> > > "service" ??
> > You can leave that field blank. I've actually no idea what it is used for.
> > --strk;
> > http://www.cartodb.com - Map, analyze and build applications with your
> > data
> > ~~ http://strk.keybit.net
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
http://www.cartodb.com - Map, analyze and build applications with your data
