[postgis-users] Error loading Postgis into ArcGIS as a Query Layer - The specified coordinate exceeds the valid coordinate range
Mark Volz MarkVolz at co.lyon.mn.us
Fri Oct 12 09:03:05 PDT 2012
Hello,
While trying to add a Postgis layer into ArcGIS as a query layer I received an error that the specified coordinate exceeds the valid coordinate range.  I don't know how to debug this error.   The data is in UTM15, and will display in QGIS.  I am able to use Postgis with ArcGIS Query Layers on another UTM layer.
One potential issue is that technically our county falls under UTM 14 and 15.  However, since the majority of the state falls inside of UTM 15, many WMS services are published only for UTM 15.  Therefore I don't know if ArcGIS is sending an error "The specified coordinate exceeds the valid coordinate range" due to the fact  that the western edge of the county is in UTM 14, and not UTM 15, or if there is another issue that I need to fix.
Thank You for any help
Mark Volz
GIS Specialist
