[postgis-users] Error loading Postgis into ArcGIS as a Query Layer - The specified coordinate exceeds the valid coordinate range
David Fawcett
david.fawcett at gmail.com
Fri Oct 12 11:08:32 PDT 2012
Occam may need a new blade on this one.
At least at version 10 and below of ArcMap, you can display a
statewide WMS like this one with no problems. The full extent of this
service covers at least 3 UTM Zones.
http://geoint.lmic.state.mn.us/cgi-bin/mncomp?request=GetCapabilities&version=1.3.0&Service=WMS&
David.
On Fri, Oct 12, 2012 at 11:49 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> On Fri, Oct 12, 2012 at 9:03 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>> One potential issue is that technically our county falls under UTM 14 and 15. However, since the majority of the state falls inside of UTM 15, many WMS services are published only for UTM 15. Therefore I don't know if ArcGIS is sending an error "The specified coordinate exceeds the valid coordinate range" due to the fact that the western edge of the county is in UTM 14, and not UTM 15, or if there is another issue that I need to fix.
> Occams razor states that you have the answer. The error message is
> very consistent with the situation you are describing. Use a
> projection that is valid for your data extent and things should be
> fine.
> P.
> postgis-users mailing list
