[postgis-users] Select polygons within polygon with PostGIS 2.0
Sandro Santilli strk at keybit.net
Mon Oct 15 08:41:10 PDT 2012
On Mon, Oct 15, 2012 at 11:37:08AM +0000, Astrid Bjørnerød wrote:
> No, I have really not understood  the way to get a link between the relation-table and the originally geo-table.
A TopoGeometry object represents that link.
> I have a table geoTable.
> All I want is to make query which returns the values of left and right polygons, like this :
>   Update geoTable set newValue = leftFace.value  where geoTable.field1 is null;  --if leftFace.Area > rightFace.Area or
>   Update geoTable set newValue = rightFace.value where geoTable.field1 is null; --if leftFace.Area < rightFace.Area
> What is the mapping between myTopo.relation element_id and the geoTable and how do I get this (which topology functions)?
You only want to query the relation table to know the composition
of your TopoGeometry. In your case this would probably be a list
of face identifiers. But you can also use functions to get that
information: GetTopoGeomElementArray or GetTopoGeomElements.
You ask:
 "[..] I want [..] the values of left and right polygons"
Left and right of what ? In the topology model we refer to
"left" and "right" of an edge. Is that what you're looking for ?
--strk;
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
