[postgis-users] Display GEOGRAPHY polygons crossing date line
Paul Ramsey pramsey at opengeo.org
Tue Oct 16 07:17:24 PDT 2012
GEarth cannot display geography *POLYGONS* that cross the dateline. It
can display linestrings just fine.
P.
On Tue, Oct 16, 2012 at 2:54 AM, iam_gilbey <simonbolivar.uk at gmail.com> wrote:
> Thanks for that info - it's something else to consider.
> Conclusion: Google Earth cannot display GEOGRAPHY data that crosses that
> date line, without a hack such as making a table of split geographies.
> Does anyone disagree? (please disagree...!)
> Thanks, James
> On 12 October 2012 17:47, Paul Ramsey-4 [via PostGIS] <[hidden email]>
> wrote:
>> Even if you split the shapes, GEarth renders polygons in a non-normal
>> kind of way which you might find unacceptable
>> http://blog.opengeo.org/2010/08/10/shape-of-a-polygon/
>> The quick fix is to render them as lines, not polygons. there's no fix
>> to get them to fill using great circle edges, GEarth just doesn't work
>> that way.
>> P.
>> On Fri, Oct 12, 2012 at 4:03 AM, iam_gilbey <[hidden email]> wrote:
>> > I have many polygons, including several that cross the date line. They
>> > are
>> > stored as GEOGRAPHY and work perfectly with PostGIS v2.0.1, PostgreSQL
>> > 9.1.3
>> > on windows XP. I can serve this data using Geoserver (v2.1), and view it
>> > using open layers, where the polygons crossing the date line render
>> > correctly.
>> > I cannot however convert the data into KML (viewed in Google Earth 5.1),
>> > or
>> > view it in Quantum GIS (v1.7), without the date line polygons being
>> > wrapped
>> > around the earth.
>> > I appreciate that this isn't strictly a postGIS problem, however being
>> > faced
>> > with the stark choice between splitting my data about the date line
>> > (inelegant) or not using Google Earth (unacceptable to users), I don't
>> > know
>> > where else to turn!
>> > Do you know of:
>> > a) a way to get the data to render correctly in Google Earth; or
>> > b) where else I should ask?
>> > Thanks!
>> > View this message in context:
>> > http://postgis.17.n6.nabble.com/Display-GEOGRAPHY-polygons-crossing-date-line-tp5000443.html
>> > Sent from the PostGIS - User mailing list archive at Nabble.com.
>> > _______________________________________________
>> > postgis-users mailing list
>> > [hidden email]
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> [hidden email]
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://postgis.17.n6.nabble.com/Display-GEOGRAPHY-polygons-crossing-date-line-tp5000443p5000464.html
>> To unsubscribe from Display GEOGRAPHY polygons crossing date line, click
>> here.
>> NAML
> View this message in context: Re: Display GEOGRAPHY polygons crossing date
> line
