[postgis-users] How to make some geometry column visible to Qgis
Pietro Rossin
pierigis at gmail.com
Fri Oct 19 02:34:42 PDT 2012
>> INSERT INTO geometry_columns (f_table_catalog,f_table_schema,
>> f_table_name,
>> f_geometry_column, coord_dimension, srid,type)
>> VALUES ('testdb','public', 'pointdata', 'geom', 3, 3004,'POINT');
>This shouldn't work, as "geometry_columns" is a view (assuming you
correctly
>installed PostGIS-2.0).
It works instead..
I saw that "geometry_columns" is a view but the method works.
The view created is correctly and immediately seen by qgis that loads the
point data.
The only problem is that it takes a year to load it..
My postgis is:
SELECT name, default_version,installed_version
FROM pg_available_extensions WHERE name LIKE 'postgis%' ;
"postgis";"2.0.0";"2.0.0"
"postgis_topology";"2.0.0";"2.0.0"
I don't understand this:
Instead you want to cast your "wkb_geometry" field to a typed geometry:
SELECT "wkb_geometry::geometry(3004, pointz), ...
I made my view like this:
CREATE OR REPLACE VIEW public.points AS
SELECT entities.ogc_fid, ST_TRANSFORM(entities.wkb_geometry,
3004)::geometry(pointz, 3004) as the_geom, entities.layer
FROM entities
WHERE entities.layer like 'mypointlayer';
Then
INSERT INTO geometry_columns (f_table_catalog,f_table_schema, f_table_name,
VALUES ('','', 'points', 'the_geom', 3, 3004,'POINTS');
It works..
But I'm learning, so if you have some hints, reccomendations or tutorial
please point me to that.
Thanks again
Pietro
View this message in context: http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000605.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
