[postgis-users] [slightly off-topic] Question on build a C address parse for an embedded geocoder
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Oct 21 11:00:48 PDT 2012
OK, I can look into doing that if I need to. I guess the appropriate
thing to do at the moment is to see if I can get things working just
loading them from tables first and see if there are performance issues
before I try to optimize it.
I should not be an issue for standardizing the reference data set,
because you only build it once for the whole reference table. I'll have
to see how much time it takes to build the lexicon tables relative to
querying the reference set to determine how much overhead there is.
Thanks,
-Steve
On 10/21/2012 12:03 PM, Paul Ramsey wrote:
> You can stuff things into an upper memory context, but I'm not sure
> how wise that would be. I does however seem to be the only reasonable
> approach to getting things to last much longer than a statement.
> P.
> On Sat, Oct 20, 2012 at 9:12 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Hi Dev's,
>> I am interested in writing an address standardized in C that could be
>> callable from SQL. I understand the basics of doing this from supporting
>> pgRouting and writing some additional commands. It would get used something
>> like:
>> select * from standardize(address, city, state, country, postcode);
>> select * from standardize(address_one_line);
>> and would return a standardized set of fields like: house_num, street, city,
>> state, country, postcode. These could be then used to create standardized
>> reference table or it could be passed into the geocoder that would search
>> the standardized reference table.
>> What I am struggling with is how to best initial the address
>> parser/standardize. The concept I have in mind is to have some tables that
>> represent the lexicon, gazetteer, parsing rules, etc. This data could be
>> specific to country and/or country-state. I could be fairly small or quite
>> large. For example, there are about 40K unique city names based on the USPS
>> zipcodes and about 7K of them have duplicate standardizations based on
>> state.
>> On the one hand I can read these tables on every request and build the
>> internal structures, parse the request, and throw out the internal
>> structures.
>> Basically once the reference source records have been standardized you
>> should not be changing the above tables because you want to standardize
>> future search requests based on the same rules that the reference road
>> segments were standardized.
>> And ideally you do not want to spend the time to rebuild these internal
>> structures on every search request.
>> So is there a mechanism for building some internal data and holding on to it
>> between requests. I suppose I could store it in a blob, but it would then
>> need to be de-toasted on every search request.
>> Maybe, I'm this is an non-issue, but it seems to impact the design depending
>> on what options I might have and how they are implemented and accessed from
>> the code.
>> Thoughts?
>> Thanks for any help or suggestions,
>> -Steve W
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
