[postgis-users] How to eliminate small gaps produced by ST_union?
pcreso at pcreso.com pcreso at pcreso.com
Thu Oct 25 10:28:19 PDT 2012
My impression is that working topologies is slow, especially with large datasets - lots of computation involved.
How effective would this be with hundreds of thousands or millions or small polygons?
Just running ST_Union() takes hours to days.
Thanks
Brent Wood
--- On Fri, 10/26/12, Sandro Santilli <strk at keybit.net> wrote:
Subject: Re: [postgis-users] How to eliminate small gaps produced by ST_union?
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Friday, October 26, 2012, 6:04 AM
You may try to construct a topology within PostGIS-2.0, using
a small tolerance, and then get the geometries back.
--strk;
On Thu, Oct 25, 2012 at 05:54:05PM +0100, Alexandre Neto wrote:
> I'm trying to Aggregate\Dissolve a set of adjacent, but not touching
> polygons in Postgis. The geometries were created editing the Postgis table
> in QGIS created, with snapping and avoid overlap in the layer.
> I used ST_Union like this:
> SELECT ST_Union(the_geom)
> FROM table;
> Small gaps similar to lines appear in the result. This happens when the
> adjacent polygons do not share the exact same vertices.
> [image: Inline image 2]
> Is there a way to eliminate this "gaps" or "small angles" within Postgis?
> I know that v.clean in GRASS can eliminate small angles, and correct
> topology, but that would mean I needed to copy the features to GRASS,
> correct them and copy it back to Postgis.
> Thanks in advance,
> Alexandre Neto
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121025/0bb5d979/attachment.html>
