[postgis-users] How to eliminate small gaps produced by ST_union?
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Oct 25 10:44:08 PDT 2012
Try to use function *st_cleanpolygon* or *st_buffer* with a radius of 0.0.
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 25-10-2012 18:54, Alexandre Neto skrev:
> I'm trying to Aggregate\Dissolve a set of adjacent, but not touching
> polygons in Postgis. The geometries were created editing the Postgis
> table in QGIS created, with snapping and avoid overlap in the layer.
> I used ST_Union like this:
> SELECT ST_Union(the_geom)
> FROM table;
> Small gaps similar to lines appear in the result. This happens when
> the adjacent polygons do not share the exact same vertices.
> Inline image 2
> Is there a way to eliminate this "gaps" or "small angles" within Postgis?
> I know that v.clean in GRASS can eliminate small angles, and correct
> topology, but that would mean I needed to copy the features to GRASS,
> correct them and copy it back to Postgis.
> Thanks in advance,
> Alexandre Neto
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121025/b8406cb4/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121025/b8406cb4/attachment.jpe>
