[postgis-users] k-nearest Polygons
Ed Linde
edolinde at gmail.com
Sat Oct 27 06:27:13 PDT 2012
Thanks. Just to clear things up, :point_or_poly bind variable needs a
"geometry"
type passed in to it, right?
Thanks,
Ed
On Sat, Oct 27, 2012 at 1:57 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Sat, Oct 27, 2012 at 01:37:05PM +0200, Ed Linde wrote:
> > Is there a way to know for a user defined "k" what the k-nearest polygons
> > to a given polygon or point are in postgis?
> -- Simple answer:
> SELECT gid from polygons
> ORDER BY ST_Distance(the_geom, :point_or_poly)
> LIMIT :k;
> More complex: if you have PostGIS-2.0 and need
> more speed the following versions do use a spatial
> index, if defined on "polygons":
> -- k nearest to bounding box of polygons:
> SELECT gid FROM polygons
> ORDER BY the_geom <#> :point_or_poly
> LIMIT :k;
> -- k nearest to polygon center:
> ORDER BY the_geom <-> :point_or_poly
> LIMIT :k;
> -- k nearest to polygon shape:
> -- NOTE: assumes the k closest objects
> -- are among the k*10 objects
> -- closer to boundingbox
> WITH k_times_10_closer AS (
> SELECT gid, the_geom FROM polygons
> LIMIT :k*10
> SELECT gid from k_times_10_closer
> LIMIT :k;
> --strk;
> http://www.cartodb.com - Map, analyze and build applications with your
> data
> ~~ http://strk.keybit.net
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121027/65bdd257/attachment.html>
