[postgis-users] k-nearest Polygons
Ed Linde
edolinde at gmail.com
Sat Oct 27 06:34:10 PDT 2012
Could you please link me to the postgis 2.0 section in the docs that talks
about
using <#> and <-> ? Those operators look quite handy to me :)
On Sat, Oct 27, 2012 at 3:32 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Sat, Oct 27, 2012 at 03:27:13PM +0200, Ed Linde wrote:
> > Thanks. Just to clear things up, :point_or_poly bind variable needs a
> > "geometry"
> > type passed in to it, right?
> Yes
> --strk;
> > Thanks,
> > Ed
> > On Sat, Oct 27, 2012 at 1:57 PM, Sandro Santilli <strk at keybit.net>
> wrote:
> > > On Sat, Oct 27, 2012 at 01:37:05PM +0200, Ed Linde wrote:
> > > > Is there a way to know for a user defined "k" what the k-nearest
> polygons
> > > > to a given polygon or point are in postgis?
> > > -- Simple answer:
> > > SELECT gid from polygons
> > > ORDER BY ST_Distance(the_geom, :point_or_poly)
> > > LIMIT :k;
> > > More complex: if you have PostGIS-2.0 and need
> > > more speed the following versions do use a spatial
> > > index, if defined on "polygons":
> > > -- k nearest to bounding box of polygons:
> > > SELECT gid FROM polygons
> > > ORDER BY the_geom <#> :point_or_poly
> > > LIMIT :k;
> > > -- k nearest to polygon center:
> > > ORDER BY the_geom <-> :point_or_poly
> > > LIMIT :k;
> > > -- k nearest to polygon shape:
> > > -- NOTE: assumes the k closest objects
> > > -- are among the k*10 objects
> > > -- closer to boundingbox
> > > WITH k_times_10_closer AS (
> > > SELECT gid, the_geom FROM polygons
> > > LIMIT :k*10
> > > SELECT gid from k_times_10_closer
> > > LIMIT :k;
> > > --strk;
> > > http://www.cartodb.com - Map, analyze and build applications with
> your
> > > data
> > > ~~ http://strk.keybit.net
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> http://www.cartodb.com - Map, analyze and build applications with your
> data
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121027/e5b5823d/attachment.html>
