[postgis-users] Difficult Problem with Polygons
Ed Linde edolinde at gmail.com
Mon Oct 29 07:37:58 PDT 2012
Hi All,
Thanks for the tips! Just another thing, when I compute the "transition
points" on each edge (shown as red points in my pdf).
I need to join them to make a polygon. Wondering how I can connect them
together so that I start with a point and end on it
to form a closed polygon?
Cheers,
Ed
On Mon, Oct 29, 2012 at 3:03 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi Ed,
> Well if clarifies one thing at least, you can ignore Mike's st_Relate
> because 5 is not adjacent to a linear edge, it is only adjacent to a
> vertex, so st_touches should work fine.
> so you are looking for:
> 1. a specific triangle by id
> 2. that intersects triangle VC
> 3. and the triangles adjacent to triangle by id
> 4. and those that are contained in VC
> 5. sorted by distance to P1 limit 1
> so something like:
> select id, the_geom
>   from (select id, the_geom as adjacent
>           from triangles
>          where st_touches(the_geom,
>                           (select the_geom
>                              from triangles a,
>                                   (select the_geom as vc
>                                      from vc_table
>                                     where id='p1') b
>                             where a.id=4)) c
>  order by st_distance(c.the_geom, (select the_geom
>                                      from points
>                                     where id='p1')) asc limit 1;
> Untested, but should give you a model to work with.
> -Steve W
> On 10/29/2012 6:57 AM, Ed Linde wrote:
>> Attached is a figure. Where the dotted line is the boundary of the
>> voronoi cell whose
>> generator is point P1. So triangle "4" intersects with the voronoi
>> boundary, but we are
>> interested in the adjacent triangles of triangle 4, which are closer to
>> point P1.
>> For example, triangle 5.
>> Hope this helps.
>> Cheers,
>> Ed
>> On Mon, Oct 29, 2012 at 11:50 AM, Nicolas Ribot <nicolas.ribot at gmail.com
>> <mailto:nicolas.ribot at gmail.**com <nicolas.ribot at gmail.com>>> wrote:
>>     Could you draw a figure ?
>>     Nicolas
>>     On 29 October 2012 11:03, Ed Linde <edolinde at gmail.com
>>     <mailto:edolinde at gmail.com>> wrote:
>>      > Hi All,
>>      > Thanks for the suggestions.
>>      > For 1) I will look into how ST_touches works and see if it can
>>     pick up all
>>      > the adjacent polygons to
>>      > the one I have. And also look into Mike's suggestion on
>>     ST_relate...though I
>>      > must admit it looks
>>      > more complex.
>>      > For 2) I will try to clarify it a bit more... its harder to do
>>     without a
>>      > figure :) but here goes.
>>      > Lets say we have a point Q which is the generator of a voronoi
>>     cell. Now I
>>      > compute the
>>      > intersection between the voronoi cell boundaries and my
>>     triangulation (Set
>>      > of polygons)
>>      > using ST_intersect. Once I have these triangles.. I say pick one
>>     triangle T
>>      > that is
>>      > intersecting the voronoi cell boundary of Q.
>>      > For all the triangles adjacent to T, I need to know which
>>     triangles are
>>      > INSIDE the voronoi
>>      > boundary (closer to Q) and which adjacent triangles are just
>>     OUTSIDE the
>>      > voronoi
>>      > boundary (farther from Q). I am basically testing for a certain
>>     property by
>>      > "shrinking" the
>>      > voronoi cell (closer to Q) and another property when "expanding"
>>     the voronoi
>>      > cell (away from Q).
>>      > Just need to make this division of triangles. Haven't thought of
>>     a nice way
>>      > to do this in postgis 2.0
>>      > So any suggestions would greatly help.
>>      > Thanks,
>>      > Ed
>>      > On Mon, Oct 29, 2012 at 10:15 AM, Mike Toews <mwtoews at gmail.com
>>     <mailto:mwtoews at gmail.com>> wrote:
>>      >> On 29 October 2012 21:33, Ed Linde <edolinde at gmail.com
>>      >> > Hi All,
>>      >> > I need help with 2 hard problems. I store triangles in a table
>> as
>>      >> > POLYGON.
>>      >> > 1. I want to know for a given triangle, which triangles share
>>     an edge
>>      >> > (adjacent) with this triangle.
>>      >> Sounds like you have a finite element mesh with nodes and
>> elements.
>>      >> You can use ST_Relate with pattern 'FF2F11212' to pick out
>> elements
>>      >> that share the same edge. This DE-9-IM is sort-of a custom
>>     ST_Touches,
>>      >> but only takes linear boundary overlaps. So if you have a table
>>      >> "elements", and you want to find ones that touch ID 567:
>>      >> SELECT elements.*
>>      >> FROM elements, elements as e
>>      >> WHERE e.id <http://e.id> = 567 AND
>>      >>     ST_Relate(elements.geom, e.geom, 'FF2F11212');
>>      >> I'm not certain about your second question.
>>      >> -Mike
>>      >> ______________________________**_________________
>>      >> postgis-users mailing list
>>      >> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>     <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>      >> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121029/a16396bf/attachment.html>
