[postgis-users] Problem with 3D polygon intersection test
Francois Hugues hugues.francois at irstea.fr
Tue Oct 30 03:19:11 PDT 2012
Maybe ST_X, ST_Y and ST_Z ?
Hugues.
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Ed Linde
Envoyé : mardi 30 octobre 2012 11:14
À : PostGIS Users Discussion
Objet : Re: [postgis-users] Problem with 3D polygon intersection test
Hi Nicolas,
Not quite sure what to make of the output from ST_DumpPoints, how do I transform it to just raw x,y,z coordinates?
 select st_astext(geomtext) from small_tris where id=0;
                       st_astext
 POLYGON Z ((10 10 805,20 10 809,10 20 814,10 10 805))
(1 row)
bounds=#  select id, st_dumpPoints( geomtext ) from small_tris where id=0;
 id |                            st_dumppoints
  0 | ("{1,1}",0101000080000000000000244000000000000024400000000000288940)
  0 | ("{1,2}",0101000080000000000000344000000000000024400000000000488940)
  0 | ("{1,3}",0101000080000000000000244000000000000034400000000000708940)
  0 | ("{1,4}",0101000080000000000000244000000000000024400000000000288940)
(4 rows)
Thanks,Ed
On Tue, Oct 30, 2012 at 11:05 AM, Ed Linde <edolinde at gmail.com> wrote:
	Ok thanks!
	On Tue, Oct 30, 2012 at 11:04 AM, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
		st_dumpRings will return the rings (closed linestrings) composing the polygon (exterior first, then interiors)
		and st_dumpPoints will return all the points forming the rings, in the right order.
		Nicolas
		On 30 October 2012 10:56, Ed Linde <edolinde at gmail.com> wrote:
			Ok, for a polygon, is there a good postgis function that can return the edges to me in the
			right sequence? Or at least the points that constitute the polygon in the right order, so I can
			generate the edges in a script?
			Thanks,
			Ed
			On Tue, Oct 30, 2012 at 10:46 AM, Ed Linde <edolinde at gmail.com> wrote:
				Ah drat! Ok then I have to basically do edge intersection tests by myself.
				Ah well. bad news! :(
				On Tue, Oct 30, 2012 at 10:44 AM, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
					st_intersection is only suitable for 2D operations. Third dimension is not taken into account.
					Nicolas
					On 30 October 2012 09:44, Ed Linde <edolinde at gmail.com> wrote:
					Hi All,
					Is there a simpler test I can do? I am quite sure that I am probably not using the right
					function in my SQL, or not doing the intersection test correctly. Is there any simpler
					way to test this 3D intersection? Am waiting on the postgis gurus to come along and
					give me some ideas, coz I am at my wits ends on this one! :) The polygons look good
					to me when I visualize them, but don't get how all triangles are found as intersecting?
					Anyway will wait.
					Cheers,
					Ed
					On Tue, Oct 30, 2012 at 9:00 AM, Ed Linde <edolinde at gmail.com> wrote:
					Hi All,
					I am having some troubles getting the ST_Intersect function to work with 3D polygons.
					I have a table to hold triangles as polygons in "small_tris"
					Another table for holding the polygonal faces of a 3D voronoi diagram in "vfaces"
					So now I am trying to do an intersection between the triangles and the voronoi faces
					to get the triangles that intersect with the faces. And it seems that *ALL* triangles
					are intersecting. I have attached a PDF where I have plotted the triangles and the
					voronoi cells. so the box around in red and blue with a major face going through is
					the voronoi diagram. The Voronoi partition in 3D is shown at the bottom too for clarity
					Can someone please help and let me know what am I doing wrong here?
					Is the select assuming something? So the polygons are flat and the intersections
					should just be lines or points. I am under some pressure to get this to work, so if
					anyone needs more information to help, the please let me know! :)
					Cheers,
					Ed
					-- TABLE SCHEMAS
					bounds=# \d vfaces;
					      Table "public.vfaces"
					  Column  |   Type   | Modifiers
					 gen_id   | integer  |
					 geomtext | geometry |
					bounds=# \d small_tris;
					    Table "public.small_tris"
					 id       | integer  | not null
					 v0       | integer  |
					 v1       | integer  |
					 v2       | integer  |
					Indexes:
					    "small_tris_pkey" PRIMARY KEY, btree (id)
					    "small_idx" gist (geomtext)
					-- TABLE CONTENT
					bounds=# select id, st_astext( geomtext ) from small_tris;
					 id |                       st_astext
					  0 | POLYGON Z ((10 10 805,20 10 809,10 20 814,10 10 805))
					  1 | POLYGON Z ((10 20 814,20 10 809,20 20 819,10 20 814))
					  2 | POLYGON Z ((20 20 819,30 10 809,30 20 812,20 20 819))
					  3 | POLYGON Z ((30 10 809,20 20 819,20 10 809,30 10 809))
					  4 | POLYGON Z ((30 20 812,30 10 809,40 10 826,30 20 812))
					  5 | POLYGON Z ((20 20 819,30 20 812,20 30 827,20 20 819))
					  6 | POLYGON Z ((10 20 814,20 20 819,20 30 827,10 20 814))
					  7 | POLYGON Z ((10 40 805,10 30 814,20 30 827,10 40 805))
					  8 | POLYGON Z ((10 50 804,10 40 805,20 40 807,10 50 804))
					  9 | POLYGON Z ((20 30 827,20 40 807,10 40 805,20 30 827))
					 10 | POLYGON Z ((30 30 817,20 40 807,20 30 827,30 30 817))
					 11 | POLYGON Z ((30 40 816,20 50 809,20 40 807,30 40 816))
					 12 | POLYGON Z ((20 40 807,20 50 809,10 50 804,20 40 807))
					 13 | POLYGON Z ((10 30 814,10 20 814,20 30 827,10 30 814))
					 14 | POLYGON Z ((30 30 817,20 30 827,30 20 812,30 30 817))
					 15 | POLYGON Z ((30 20 812,40 20 823,30 30 817,30 20 812))
					 16 | POLYGON Z ((40 20 823,30 20 812,40 10 826,40 20 823))
					 17 | POLYGON Z ((40 20 823,40 10 826,50 10 803,40 20 823))
					 18 | POLYGON Z ((30 30 817,40 20 823,40 30 814,30 30 817))
					 19 | POLYGON Z ((40 20 823,50 20 808,40 30 814,40 20 823))
					 20 | POLYGON Z ((50 20 808,40 20 823,50 10 803,50 20 808))
					 21 | POLYGON Z ((40 30 814,50 20 808,50 30 816,40 30 814))
					 22 | POLYGON Z ((30 30 817,40 30 814,40 40 800,30 30 817))
					 23 | POLYGON Z ((30 40 816,40 40 800,30 50 813,30 40 816))
					 24 | POLYGON Z ((30 40 816,30 30 817,40 40 800,30 40 816))
					 25 | POLYGON Z ((30 50 813,40 40 800,40 50 817,30 50 813))
					 26 | POLYGON Z ((30 40 816,30 50 813,20 50 809,30 40 816))
					 27 | POLYGON Z ((50 40 821,40 50 817,40 40 800,50 40 821))
					 28 | POLYGON Z ((50 50 809,40 50 817,50 40 821,50 50 809))
					 29 | POLYGON Z ((50 40 821,40 40 800,50 30 816,50 40 821))
					 30 | POLYGON Z ((40 30 814,50 30 816,40 40 800,40 30 814))
					 31 | POLYGON Z ((30 30 817,30 40 816,20 40 807,30 30 817))
					(32 rows)
					 select st_astext(geomtext) from vfaces;
					                                           st_astext
					 POLYGON Z ((51 17.8 799,9 38.8 799,9 51 819.33333333333,19.4 51 828,51 35.2 828,51 17.8 799))
					 POLYGON Z ((51 17.8 799,9 38.8 799,9 51 799,51 51 799,51 17.8 799))
					 POLYGON Z ((51 35.2 828,19.4 51 828,51 51 828,51 35.2 828))
					 POLYGON Z ((9 9 799,9 38.8 799,51 17.8 799,51 9 799,9 9 799))
					 POLYGON Z ((9 9 828,9 51 828,19.4 51 828,51 35.2 828,51 9 828,9 9 828))
					(6 rows)
					select distinct a.id
					from small_tris a, vfaces b
					where st_intersects (a.geomtext, b.geomtext)
					order by a.id;
					 id
					  0
					  1
					  2
					  3
					  4
					  5
					  6
					  7
					  8
					  9
					 10
					 11
					 12
					 13
					 14
					 15
					 16
					 17
					 18
					 19
					 20
					 21
					 22
					 23
					 24
					 25
					 26
					 27
					 28
					 29
					 30
					 31
					(32 rows)
					postgis-users mailing list
					postgis-users at postgis.refractions.net
					http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121030/0cf99e07/attachment.html>
