[postgis-users] How to re-tile a raster after union ?
Bborie Park
bkpark at ucdavis.edu
Wed Oct 31 14:12:41 PDT 2012
Francois,
You are correct. ST_Tile() doesn't exist in 2.0 but a prototype can be
found in the raster/scripts/plpgsql directory.
You really ought to upgrade PostGIS to 2.0.1 as there were a bunch of
bug fixes there.
-bborie
On 10/31/2012 12:59 PM, Francois Hugues wrote:
> Hi,
> I have a tiled dem which I want to use to calculate slopes. If I want to avoid the border effect between each tile, I have to use st_union (the faster version, thanks to P. Racine).
> But, if I'm not wrong, I will obtain a single tile raster. The answer to my question is maybe so obvious that I can't see it, but how can I re-tile my raster in a new table. Is there no other way to tile than to use raster2pgsql ? I'm surprised that there is no postgis function for that so I think I may miss something.
> Thanks for your answer and advices !
> Hugues.
> PS : I'm trying to clip my raster to reduce time, but I have a problem with ST_Clip. After little googling, I saw that few people had this error but I did not find the solution. Does an upgrade should solve this issue ?
> ERROR: rt_raster_gdal_rasterize: Unable to add band to GDALDataset
> CONTEXT: PL/pgSQL function "st_asraster" line 26 at RETURN PL/pgSQL function "st_clip" line 36 at assignment
> "POSTGIS="2.0.0 r9605" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8" LIBJSON="UNKNOWN" (core procs from "2.0.0rc1 r9576" need upgrade) TOPOLOGY (topology procs from "2.0.0rc1 r9576" need upgrade) RASTER (raster procs from "2.0.0rc1 r9576" need upgrade)"
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
