[postgis-users] GDAL Version
Bborie Park
bkpark at ucdavis.edu
Tue Sep 4 11:35:01 PDT 2012
Yes. PostGIS raster uses GDAL for the loader (for the numerous source
raster formats), warping API, one of the two possible polygonization
methods (ST_DumpAsPolygons) and the rasterization function.
The main reason for GDAL 1.9 is correct output of pixel values from
ST_DumpAsPolygons which consumes GDAL's polygonization methods.
-bborie
On 09/04/2012 11:23 AM, Brian Fitzgerald wrote:
> Are you saying that Postgis should be using GDAL 1.9?
> Thx!
> - Brian
> On Tue, Sep 4, 2012 at 2:08 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
>> Issues with QGIS accessing PostGIS raster typically arises from the GDAL
>> version used by QGIS. Some of the issues with GDAL's PostGIS raster
>> driver have been resolved in GDAL trunk. Since it looks like you're
>> already running trunk for QGIS and PostGIS, you might as well be running
>> GDAL trunk.
>> -bborie
>> On 09/04/2012 10:55 AM, Brian Fitzgerald wrote:
>>> Does anyone know if PostGIS 2.0 raster support requires PostGIS to use
>> GDAL
>>> 1.9? I'm having problems opening PostGIS 2.0 raster layers inside QGIS
>> and
>>> am thinking it may have something to do with the GDAL version of Postgis
>>> 2.0. When I run a
>>> select postgis_full_version();
>>> I get:
>>> "POSTGIS="2.1.0SVN" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23
>> September
>>> 2009" GDAL="GDAL 1.7.3, released 2010/11/10" LIBXML="2.7.8"
>>> LIBJSON="UNKNOWN" (core procs from "2.1.0SVN" need upgrade) RASTER
>> (raster
>>> procs from "2.1.0SVN" need upgrade)"
>>> I'm running all of this on a linux mint 13 stack with postgres 9.1.5 and
>>> have confirmed that my QGIS 1.9.0 nightly is leveraging GDAL 1.9.1
>>> Thx!
>>> - Brian
>>> Brian Fitzgerald, PMP, GISP
>>> bkfitz at gmail.com
>>> 803.426.3469
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Bborie Park
>> Programmer
>> Center for Vectorborne Diseases
>> UC Davis
>> 530-752-8380
Bborie Park
Programmer
UC Davis
530-752-8380
