[postgis-users] Creating a simple polygon encompassing a given number of points
René Fournier
m5 at renefournier.com
Mon Sep 10 18:44:11 PDT 2012
Thanks Nicolas,
I've gotten a bit farther. Stuck again though. This works:
SELECT ST_AsText(ST_ConvexHull(ST_Collect(ST_GeomFromText('MULTIPOINT(50.569455 -111.868842, 50.569992 -111.898634, 50.583764 -111.907919, 50.569452 -111.868859)') ) ));
st_astext
POLYGON((50.583764 -111.907919,50.569992 -111.898634,50.569452 -111.868859,50.569455 -111.868842,50.583764 -111.907919))
But for some reason, I can't update:
UPDATE territories SET border = ST_ConvexHull(ST_Collect(ST_GeomFromText('MULTIPOINT(50.569455 -111.868842, 50.569992 -111.898634, 50.583764 -111.907919, 50.569452 -111.868859)') ) ) WHERE id = 3014;
ERROR: cannot use aggregate function in UPDATE
LINE 1: UPDATE territories SET border = ST_ConvexHull(ST_Collect(ST_...
Any ideas? I'm new to these functions.. Ultimately, I want to update territory with a set of points from a SELECT, e.g.:
SELECT location FROM addresses WHERE territory_id = 3014;
Table "public.addresses"
Column | Type | Modifiers | Storage | Description
id | integer | not null default nextval('addresses_id_seq'::regclass) | plain |
territory_id | integer | not null | plain |
location | geography(Point,4326) | | main |
On 2012-09-10, at 12:46 PM, Nicolas Ribot wrote:
> Hi,
> You could use st_convexHull on the point set and then buffer it with st_buffer.
> (st_concaveHull may give you better results on polygon approximation
> (see: http://postgis.refractions.net/documentation/manual-2.0/ST_ConcaveHull.html)
> Nicolas
> On 10 September 2012 20:39, René Fournier <m5 at renefournier.com> wrote:
>> I've written a script to migrate location data from MySQL to PostGIS.
>> Each region contains 5-20 locations. I would like my script to create a simple polygon for each region that encompasses its locations (lat/lng points). I say simple in the sense of not too many vertices (< 10), even if the region contains 20 points.(The easiest thing would be a bounding box, but I would like it a bit more defined than that.) Additionally, I would like the polygon to be a bit bigger (say, by 10 meters) than the points it contains.
>> Just wondering if this is something that can be done in a PostGIS query or PHP using some algorithm for simple. What would you recommend? Thanks!
>> ...Rene
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120910/53199279/attachment.html>
