[postgis-users] ST_DWithin is not using SpatialIndex with Subquery
Thomas Klemmer
thomas.klemmer at gmail.com
Tue Sep 11 02:09:02 PDT 2012
Hi folks
first of here some system informations:
Server: Ubuntu 12.04 LTS, 16GB RAM 1TB 4x SSD HW Raid
"PostgreSQL 9.1.5 on x86_64-unknown-linux-gnu, compiled by gcc
(Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit"
"POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
LIBJSON="UNKNOWN" TOPOLOGY RASTER"
Database:
TableName: PointTbl_v1
Index: idx_pdb_v1
NumRows: 4.09806e+08
TableSize: 280 GB
IndexSize: 21 GB [Gist on(point_pos)]
GeometryCo: point_pos
Type: POINT
Dimensions: 2
SRID: 4326
TableName: PointTbl_v5
Index: idx_pdb_v5
NumRows: 4.16218e+07
TableSize: 19 GB
IndexSize: 2344 MB [Gist on(point_pos)]
Primarykey: false
Type: POINT
Dimensions: 2
SRID: 4326
TableName: NetTbl
Index: idx_net
NumRows: 270615
TableSize: 195 MB
IndexSize: 17 MB
Primarykey: NetTbl_pk
GeometryCo: net_geom
Type: LINESTRING
Dimensions: 2
SRID: 4326
Basically I'm trying to gather all points from PointTbl_v5 / PointTbl_v1
that are close or on a LineString in NetTbl;
Here ist the Query I'm trying to run:
SELECT ST_AsBinary(point_pos) AS point_pos, oid, ..., type
FROM PointTbl_v5
WHERE ST_DWithin(point_pos,(SELECT net_geom from NetTbl where ogc_fid =
500) ,5e-05);
This query takes 319005 msec to return which is very slow due to the a seq
scan done on PoinDB_v5
EXPLAIN ANALYSE
"Seq Scan on PointTbl_v5 (cost=10000000008.36..10013364820.01
rows=13873927 width=202) (actual time=199926.978..318895.494 rows=5
loops=1)"
" Filter: st_dwithin(point_pos, $0, 5e-05::double precision)"
" InitPlan 1 (returns $0)"
" -> Index Scan using NetTbl_pk on NetTbl (cost=0.00..8.36 rows=1
width=847) (actual time=2.069..2.075 rows=1 loops=1)"
" Index Cond: (ogc_fid = 2)"
"Total runtime: 318895.583 ms"
The query:
SELECT ST_AsText(net_geom) from NetTbl where ogc_fid = 2
returns in 16 ms;
If I instert the Geometry by Hand into the first query like this:
SELECT ST_AsBinary(point_pos) AS point_pos, oid, country, federalstate,
district, town
FROM PointTbl_v5
WHERE ST_DWithin(point_pos, ST_GeomFromText(
'LINESTRING(....)',4326),5e-05);
This query return in 63ms on the small table and 766ms on the bigger table.
EXPLAIN ANALYSE
"Index Scan using idx_pdb_v5 on PointTbl_v5 (cost=0.00..147.61 rows=1
width=202) (actual time=0.047..1.050 rows=23 loops=1)"
" Index Cond: (point_pos && '0103.....A40'::geometry)"
" Filter: (('0102.....4A40'::geometry && st_expand(point_pos,
5e-05::double precision)) AND _st_dwithin(point_pos,
'01020.....A40'::geometry, 5e-05::double precision))"
"Total runtime: 1.080 ms"
Does anybody have a clue why the first query with the subquery for the
LineString Geometry withing ST_DWithin not using the Spatial index?
seqscan_enabled is turned off...
cheers Thomas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120911/fbc632ff/attachment.html>
