[postgis-users] Creating a simple polygon encompassing a given number of points
René Fournier
m5 at renefournier.com
Wed Sep 12 08:42:56 PDT 2012
Yes, this works great.
UPDATE territories SET border = (SELECT ST_ConvexHull(ST_Collect(ST_GeomFromText('MULTIPOINT(-111.868842 50.569455, -111.898634 50.569992, -111.907919 50.583764, -111.868859 50.569452)') ) )) WHERE id = 3014;
Now... I'm trying to figure out, how to do the same, except create the border (polygon) from points in another table, e.g.:
SELECT location FROM addresses WHERE territory_id = 3014
))) WHERE id = 3014;
...returns "ERROR: function st_collect(geography) does not exist HINT: No function matches the given name and argument types. You might need to add explicit type casts."
So I'm wondering, since both border (final polygon) and location (source of points) are of type geography, what's the best way to go about this? Or should I have just used geometry types? Sorry for the dumb questions, I'm trying to define the schemas by best practices so I don't have to fix them later. Geography seemed right when I started the project.
On 2012-09-11, at 1:18 AM, Paolo Corti wrote:
> On Tue, Sep 11, 2012 at 3:44 AM, René Fournier <m5 at renefournier.com> wrote:
>> Thanks Nicolas,
>> ST_ConvexHull(ST_Collect(ST_GeomFromText('MULTIPOINT(50.569455 -111.868842,
>> 50.569992 -111.898634, 50.583764 -111.907919, 50.569452 -111.868859)') ) )
>> WHERE id = 3014;
>> ERROR: cannot use aggregate function in UPDATE
>> LINE 1: UPDATE territories SET border = ST_ConvexHull(ST_Collect(ST_...
> Using a sub-select should work:
> -111.868842, 50.569992 -111.898634, 50.583764 -111.907919, 50.569452
> -111.868859)') ) ))
> WHERE id = 3014;
> regards
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120912/dbd55b87/attachment.html>
