[postgis-users] CentOS PostGIS installation problem
Carol Peck
carolapeck at gmail.com
Thu Sep 13 18:34:45 PDT 2012
I'm trying to get PostGIS running on CentOS 5.8 (on a VPS). I have
Postgres 8.4 installed from rpm. I built PostGIS 1.5 from source,
install and make went properly.
When I try to run postgis.sql I get the following, starting with the
first line:
psql:/usr/share/pgsql/contrib/postgis-1.5/postgis.sql:59: ERROR: could
not load library "/usr/lib64/pgsql/postgis-1.5.so": libgeos_c.so.1:
cannot open shared object file: No such file or directory
and then later after aborted transaction errors:
psql:/usr/share/pgsql/contrib/postgis-1.5/postgis.sql:7782: ERROR: type
"box2d" does not exist
psql:/usr/share/pgsql/contrib/postgis-1.5/postgis.sql:7783: ERROR: type
"geometry" does not exist
psql:/usr/share/pgsql/contrib/postgis-1.5/postgis.sql:7791: ERROR: type
"geometry[]" does not exist
Thanks in advance for any help!
