[postgis-users] RE : RE : How to change the SRID of a table ingeometry_columns view
Francois Hugues
hugues.francois at irstea.fr
Fri Sep 14 02:31:47 PDT 2012
Hello Nicolas,
Finally, one simple question and three different ways to accomplish the same task. Even when it is simple, we can learn something to make it more simple !
I don't know what is the problem with my replies because I didn't know there was any problem. I simply use my mailing software... But I'll take a look at it.
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at postgis.refractions.net de la part de Nicolas Ribot
Date: ven. 14/09/2012 11:06
À: PostGIS Users Discussion
Objet : Re: [postgis-users] RE : How to change the SRID of a table ingeometry_columns view
> Hello,
> I think you do not have to change the view but only update the original table using st_SetSRID (http://postgis.org/docs/ST_SetSRID.html) and the view should be automatically update.
> To change the SRID from your table you will certainly have to remove constraints first.
> Hugues.
Hi Hugues,
Sorry, did not see your answer.
(by the way, do you know why your replies appears as a new thread
instead of appending to the original thread ?)
Nicolas
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120914/8810bdfa/attachment.bin>
