[postgis-users] Odd question
Paragon Corporation lr at pcorp.us
Sat Sep 15 16:44:17 PDT 2012
Eric,
Did y ou want to change the default or set it to 0 or something?
We were meaning to expose that but wasn't sure if anyone would be interested
in changing it.
The setting is on the function:
interpolate_from_address
Just change the hardcoded default of 10 to what you want.
CREATE OR REPLACE FUNCTION interpolate_from_address(given_address INTEGER,
in_addr1 VARCHAR, in_addr2 VARCHAR, in_road GEOMETRY,
	in_side VARCHAR DEFAULT '',in_offset_m float DEFAULT 10 );
In 2.1. we'll add to the list to allow this to be voerrided at the geocode
function level as an additional arg.  Can't do that with the 2.0 one though
since that would change the api.
Hope that helps,
Regina
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Eric
Aspengren
Sent: Saturday, September 15, 2012 5:20 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Odd question
Anybody know how to remove the default 10 meter offset from the PostGIS
geocoder?
Eric Aspengren
(402) 478-8683
www.streetlevelstrategies.com
ericaspen at gmail.com
