[postgis-users] Odd question
Chris English
sglish at hotmail.com
Mon Sep 17 06:45:23 PDT 2012
Thank you, now perfectly clear.
To: postgis-users at postgis.refractions.net
Date: Mon, 17 Sep 2012 00:35:16 -0400
Subject: Re: [postgis-users] Odd question
The offset is to get you on the right side of the street, not to
compensate for the fuzzyness of census data.
Not sure if that was clear. The census data are all street
centerlines, and what the offset is intended to do is this
Say your road looks like this:
0
24 30
1 25 31
Say
lets say your street address is like 25 State street, the interpolation would
put you on the centerline of the line corresponding to
24/25
But
since we know you are 25 -- the 10 offset pushes the point to hit the 25 (so 10
meters) in the 25 direction
So the
offset should be more accurate than without as it would put you on the correct
side of the road instead of standing in the middle of
it.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Chris
English
Sent: Sunday, September 16, 2012 9:14 AM
To:
postgis_users
question
But changing the setting to zero doesn't get one necessarily closer
to the
true location of the address, does it? It remains fuzzy as was
the intent
of the census bureau to elide.
Chris
Date: Sat, 15 Sep 2012 18:46:06 -0500
To:
question
That's fantastic! Exactly what I was looking for. Thank you very
much.
On Sat, Sep 15, 2012 at 6:44 PM, Paragon Corporation
<lr at pcorp.us>
wrote:
Eric,
Did y ou want to change the default or set
it to 0 or something?
We were meaning to expose that but wasn't sure if
anyone would be interested
in changing it.
The setting is on the
function:
interpolate_from_address
Just change the hardcoded
default of 10 to what you want.
CREATE OR REPLACE FUNCTION
interpolate_from_address(given_address INTEGER,
in_addr1 VARCHAR, in_addr2
VARCHAR, in_road GEOMETRY,
in_side VARCHAR
DEFAULT '',in_offset_m float DEFAULT 10 );
In 2.1. we'll add to the
list to allow this to be voerrided at the geocode
function level as an
additional arg. Can't do that with the 2.0 one though
since that
would change the api.
Hope that helps,
Regina
http://www.postgis.us
-----Original Message-----
On Behalf Of Eric
Aspengren
Sent: Saturday, September 15, 2012 5:20
PM
To: PostGIS Users Discussion
Subject: [postgis-users] Odd
question
Anybody know how to remove the default 10 meter offset from
the PostGIS
geocoder?
Eric Aspengren
(402) 478-8683
www.streetlevelstrategies.com
ericaspen at gmail.com
postgis-users
http://postgis.refractions.net/mailman/listinfo/postgis-users
Eric Aspengren
(402) 478-8683
postgis-users mailing list postgis-users at postgis.refractions.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120917/365a1bde/attachment.html>
