[postgis-users] out of db raster path?
Bborie Park bkpark at ucdavis.edu
Mon Sep 17 11:50:21 PDT 2012
Yep.  You always need to provide the absolute path for the file.  This
is because there is no agnostic way (across different OSes) to determine
the absolute path of a raster file from raster2pgsql.
-bborie
On 09/17/2012 10:55 AM, G. Allegri wrote:
> I simply had to pass the full path to raster2pgsql...
> giovanni
> Sent from Nexus
> Il giorno 17/set/2012 18:47, "G. Allegri" <giohappy at gmail.com> ha scritto:
>> I've loaded an out of db raster which points to an .adf file (arcinfo
>> binary grid).
>> Whenever I operate on the column I obatin
>> "rt_band_load_offline_data: Cannot open offline raster hdr.adf"
>> Question: is the file path saved or just the file name?
>> giovanni
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
