[postgis-users] loading raster into DB takes more then an hour
Bborie Park
bkpark at ucdavis.edu
Mon Sep 17 11:54:55 PDT 2012
Yes, no and maybe. You haven't given sufficient information about your
environment to provide any informed advice.
What is your raster2pgsql command?
Are you piping the output from raster2pgsql directly to psql? Or
loading from a file containing the output?
What OS? PostgreSQL version?
-bborie
On 09/17/2012 09:10 AM, G. Allegri wrote:
> I'm loading a DEM (float, single band, 27654x17623) through raster2pgsql
> and it takes more then hour to complete.
> It happens both with tiled loading (256x256) and single block.
> Is it normal?
> giovanni
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
