[postgis-users] Postgis 1.5 core dumps on GEOSIntersects with side location conflict
Adam work.asr at gmail.com
Thu Sep 20 07:37:14 PDT 2012
Running this query against Postgis 1.5 causes a core dump:
SELECT ST_intersects(
   geomfromtext('POLYGON((31.904296875 67.32421875,14.58984375
67.32421875,12.744140625 65.830078125,33.75 66.09375,31.904296875
67.236328125,31.81640625 67.32421875,31.904296875 67.32421875))', 4326),
Running against Postgis 2.0 gives the following error (much preferred to
get an error than a core dump!):
ERROR:  GEOSIntersects: TopologyException: side location conflict at
CONTEXT:  SQL function "st_intersects" statement 1
Both are using geos version: '3.3.5-CAPI-1.7.5'.
Unfortunately upgrading to Postgis 2 is not an option for us.
Our platform is Solaris 10 x86 using 64 bit builds.
>From dbx the core file shows:
  [1] 0x1b408d(0x1, 0x1, 0x474e5543432b2b00, 0xbe0170, 0xfffffd7fffdf8880,
0x1b408d), at 0x1b408d
  [2] _Unwind_RaiseException_Body(0x0, 0x0, 0x0, 0x0, 0x0, 0x0), at
0xfffffd7ffec416bc
  [3] _SUNW_Unwind_RaiseException(0x0, 0x0, 0x0, 0x0, 0x0, 0x0), at
0xfffffd7ffec418a9
  [4] __cxa_throw(obj = (nil), tinfo = (nil), dest = (nil)), line 75 in
"eh_throw.cc"
  [5] geos::geomgraph::EdgeEndStar::propagateSideLabels(this =
0xfffffd7ffe6e2a00, geomIndex = 0), line 69 in "new_allocator.h"
  [6]
_ZN4geos9geomgraph11EdgeEndStar16computeLabellingEPSt6vectorIPNS0_13GeometryGraphESaIS4_EE(this
= 0x91bc10, geomGraph = 0xfffffd7fffdf8e18), line 88 in "EdgeEndStar.cpp"
  [7] geos::operation::relate::RelateComputer::labelNodeEdges(this =
0xfffffd7fffdf8e30), line 327 in "RelateComputer.cpp"
  [8] geos::operation::relate::RelateComputer::computeIM(this =
0xfffffd7fffdf8e30), line 131 in "RelateComputer.cpp"
  [9] geos::operation::relate::RelateOp::relate(a = (nil), b = (nil)), line
43 in "RelateOp.cpp"
  [10] geos::geom::Geometry::intersects(this = 0x91b598, g = 0x91b638),
line 191 in "memory"
  [11] GEOSIntersects_r(extHandle = 0x91d100, g1 = (nil), g2 = (nil)), line
351 in "geos_ts_c.cpp"
  [12] GEOSIntersects(g1 = (nil), g2 = (nil)), line 139 in "geos_c.cpp"
  [13] intersects(fcinfo = 0xfffffd7fffdf9110), line 2322 in "lwgeom_geos.c"
  [14] ExecMakeFunctionResult(fcache = 0xfffffd7fffdf90d0, econtext =
0xbd5740, isNull = 0xbd6c28 "", isDone = (nil)), at 0x5a9d88
  [15] ExecEvalAnd(andExpr = (nil), econtext = 0xbd5740, isNull = 0xbd6c28
"", isDone = (nil)), at 0x5aaf23
  [16] ExecProject(projInfo = 0xbd6c40, isDone = 0xfffffd7fffdf95bc), at
0x5ae659
  [17] ExecResult(node = 0xbd5630), at 0x5ba7d0
  [18] ExecProcNode(node = 0xbd5630), at 0x5a77ec
  [19] standard_ExecutorRun(queryDesc = 0xbcd2e8, direction =
ForwardScanDirection, count = 1), at 0x5a550c
  [20] fmgr_sql(fcinfo = 0xfffffd7fffdf9880), at 0x5b1529
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120920/28d726ca/attachment.html>
