[postgis-users] Selecting which table column to update
Bob Pawley rjpawley at shaw.ca
Mon Sep 24 10:42:10 PDT 2012
Hi
I am attempting to update a table column that is to be determined by a linestring being above, below or to the right of an intersection.
update pipe
    set
    case when st_centroid(bob.edge_data.geom) >> num_search.the_geom9
        where bob.edge_data.edge_id <> pipe.edge
        and pipe.id =10
        then branch_right_id =
        when st_centroid(bob.edge_data.geom) |>> num_search.the_geom9
        and pipe.id =10
        then branch_up_id =
        when st_centroid(bob.edge_data.geom) <<| num_search.the_geom9
        and pipe.id =10
        then branch_down_id =
        end
    (select bob.edge_data.edge_id
        from bob.edge_data, num_search, pipe
        where st_intersects(bob.edge_data.geom, num_search.the_geom9))  --intersection of max edge collected in pipe table
    where pipe.id = 10;
Following is the error-
ERROR:  syntax error at or near "case"
LINE 3:  case when st_centroid(bob.edge_data.geom) >> num_search.the...
Can this be done?
Bob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120924/d226da57/attachment.html>
