[postgis-users] ST_StartPoint() for MultiLineStrings
Martin Davis mtnclimb at telus.net
Thu Sep 27 08:06:38 PDT 2012
In which case why not just extend ST_StartPoint to include this
behaviour?  Always nicer to keep the function list as short as possible.
On 9/27/2012 7:31 AM, David William Bitner wrote:
> Perhaps to match a number of people's expectations, there should be an
> ST_First Point() that is basically
> ST_StartPoint(ST_GeometryN(ST_Multi(geometry),1))
> On Tue, Sep 25, 2012 at 4:08 PM, Paul Ramsey <pramsey at opengeo.org
> <mailto:pramsey at opengeo.org>> wrote:
>     When ST_NumGeometries == 1, you can run ST_StartPoint on
>     ST_GeometryN(geom,1). Where ST_NumGeometries > 1 you are in
>     "interpretation land". What's the start point of a geometry with two
>     lines?
>     P.
>     On Tue, Sep 25, 2012 at 1:38 PM, David Quinn
>     <daithiquinn at gmail.com <mailto:daithiquinn at gmail.com>> wrote:
>     > As ST_StartPoint( multilinestring ) returns NULL for PostGIS 2.0
>     > (http://postgis.refractions.net/docs/ST_StartPoint.html ), what
>     > approach can be used to identify the start and end points of a
>     > multilinestring?
>     > Thanks,
>     > David
>     > _______________________________________________
>     > postgis-users mailing list
>     > postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>     > http://postgis.refractions.net/mailman/listinfo/postgis-users
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2012.0.2221 / Virus Database: 2441/5293 - Release Date: 09/26/12
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120927/b5932eb7/attachment.html>
