[postgis-users] where is postgis.sql?
Mike Toews
mwtoews at gmail.com
Sat Sep 29 14:32:49 PDT 2012
Hi Vince,
What operation system? What method did you install? If you have
pg_config installed (part of the development package of postgres), you
can find the share and contrib directory:
$ ls `pg_config --sharedir`/contrib
But, since you are using 9.1, you should use the extension method of
attaching postgis. From psql/pgAdmin in your target database, use the
DDL command:
CREATE EXTENSION postgis;
-Mike
On 30 September 2012 06:28, Vince Miller <vincentpmiller at yahoo.com> wrote:
> Newby question: I want to attach postgis to my new db. Postgresql 9.1 seemed to install fine, but I can't find postgis.sql. Where is it? It's not in /usr/share/.../contrib as I'm given to expect. I don't want to compile from source to get it, if I don't have to. What's its relationship to postgis.sql.in.c?
> Thanks for your help.
