[postgis-users] Analyze a timeline of geographical events
Lorenzo Perone
lorenzo.perone at gmail.com
Fri Aug 2 01:11:26 PDT 2013
2013/8/1 Brent Wood <pcreso at pcreso.com>
> Hi Lorenzo,
> It is not clear what the geometry type of a waypoint_sessione is. I'm
> guessing it is a point, with each point joined by sessione_id to a sessione
> table.
It's right :)
> The polyline approach you mention should work for you. It is not that
> difficult to implement as a script, might be trickier as a Postgres UDF.
I don't know Postgres UDF, I'll take a look at it.
> Turn your session points into a (multi?)linestring.
I've put them in LINESTRING, after the clip (I'm trying to resolve the
problem into several steps) I've put the in a MULTILINESTRING geometry.
> Clip the linestring by the buffer around the point. This will give a
> linestring for each seperate period the session track came within the
> buffer distance of the point.
> For each returned linestring, select the points that match your
> requirements (<7km/hr) that intersect the linestring (or perhaps a very
> small buffer of it - point/line intersections can be tricky - but this case
> should be OK), and from these, select the min/max times.
> If these are more than 10 mins apart, check that there are no points
> within this interval with speeds of > 7km (if so, then this sequence fails
> to meet your criteria),
> If not, you have a positive result.
Great, I was not able to find the solution of this step, I'll try.
> HTH,
> Brent Wood
Thanks a lot Brent.
l.
Lorenzo Perone
photoblog: http://lorenzoperone.wordpress.com
website: http://blog.spaziogis.it
GEO+ geomatica in Italia *http://bit.ly/GEOplus*
> *From:* Lorenzo Perone <lorenzo.perone at gmail.com>
> *To:* postgis-users at lists.osgeo.org
> *Sent:* Friday, August 2, 2013 1:09 AM
> *Subject:* [postgis-users] Analyze a timeline of geographical events
> Hi,
> I'm trying to resolve a not easy (for me) problem.
> We are developing a GPS tracking system based on android phones.
> The waypoints transmitted by the devices are stored in a Postgis table
> called "waypoint_sessione".
> The table has this structure.
> TABLE waypoint_sessione
> gid bigserial
> sessione_id bigint number of the session opened by the device (depends by
> user, truck, device)
> time_dataora bigint (unix timestamp)
> elevazione double precision
> direzione double precision
> velocita double precision (speed)
> pdop double precision
> precisione integer
> the_geom geometry
> My scope is to discover for each session if a user have spent a lot of
> time, more than 10 minutes, stopped whitin a 150 m buffer from known point.
> When a device is stopped his speed is not zero, so I need to use a speed
> threshold, tipically 7 Km/h.
> I've thought to proceed in this way:
> - Create a buffer form the known point
> - Select the waypoints in the buffer grouping them by sessione_id
> Here is the first doubt.
> If the user, it's easy, pass through the buffer more than one time for
> each session I've to group the waypoints non only by session_id but also
> for each passage.
> I can't use the gid column because in waypoint_sessione are stored datas
> from al large number of devices that are transmitting simultaneous.
> I could create a polyline for each session and then trim it by the buffer
> and select the waypoints that are the same of the node of the polyline for
> each part.
> Is there a simpler way?
> The step forward is, for each group of waypoints, to discover if I have a
> consecutive period of more than 10 minutes during wich the speed is below
> the threshold of 7 Km/h.
> Discover these periods is my goal.
> Thanks.
> lorenzo
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130802/b9e71fae/attachment.html>
