[postgis-users] Problem in a spatial query
Lelo - Luiz Rogério De Pieri
lelo.pieri at gmail.com
Mon Aug 5 11:32:29 PDT 2013
Hi Diego,
What about remove ::geography from your query?
On Mon, Aug 5, 2013 at 3:26 PM, Diego Roberto <diegorrborges at gmail.com>wrote:
> Hello I am conducting a survey to check if a point that I am trying to
> insert already exists a point near recorded in a radius of 300 meters.
> I use this query to perform this procedure:
> SELECT i.id_impediments
> FROM impediments AS i
> WHERE st_dwithin(
> GeomFromText('POINT(-49.256452 -16.674886)',4326)::geography,
> i.geometry_data,
> 300)
> So far so good, however for coordinates outside the 'Brazil' displays the
> following error:
> Coordinate values are out of range [-180 -90, 180 90] for GEOGRAPHY type
> Following SQL:
> WHERE st_dwithin(
> GeomFromText('POINT(37.797848 -122.466774)',4326)::geography,
> i.geometry_data,
> 300) AND i.id_type =5
> How should I treat this information, can someone help me? The way I'm
> working is correct?
> Thank you.
> Diego.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Rogério De Pieri (Lelo)
MBA em Gerenciamento de Projetos - FGV
SCJP 5
Buscando melhorar a cada dia
Áudio, Hardware & Software
www.twitter.com/lelopieri
blogdolelo.wordpress.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130805/bf2cf359/attachment.html>
